totally agree which is why I have stayed with what Ive got till now and ran full r34 gtr brembos for years till I went past that limit
obviously the above brake kit is genuinely to the upper end of any braking system needed for most motorsport and maybe overkill but still have to have the hardware to do the job and not just
Even just sprint/ time attack 1 or 2 lap dash type thing what I have on now, which is at the lower end of where youd want to be, at SMP in 14 hot laps over 3 days I chewed about 70% of a new rotor and pads where ran at 60 % of max power half the time and other at 80% power the brakes did OK for my first go but also really only because of ABS was letting me go past where I should.
We also found by T8 hairpin on first hot lap it was starting to get hmmmm and T10 i was pretty much trail braking through necessity due to brake fade and thats on the ABS let alone another lap
will now be looking to run at least 20% more power than previously + some other things on a full hot lap
So if you go a kit in between what I had and now and the above - itd still be an awesome big brake kit so same would still apply its tyre grip and would it do the job yes - but but calculation and speaking with others once again just or still running it at 90% capacity and tbh the price difference isnt that much
Hopefully with this there are no if, but, maybes and once again the only let down may become driver skill / ability which Im OK with
  • Like 1
On 06/03/2024 at 3:20 PM, bcozican said:
nice - pain in the butt to get that in and setup/ installed but good when done - you running sensors off hubs not shafts yeah ?
Yeah, I just called Brad and he sent me the shit. Top guy to deal with, just get's it done.
Have you sorted the whole "tearing sub frames out under brakes"?
Also, what have you got done in the way of ducting to keep the brakes cool? What is the air into, and out of that area like for flow?
Do you feel there's a possibility you're straight up lacking some cooling flow to keep things going?
I know you've got a lot of grip, and power, but not even a full hot lap without fade on the original brake setup, I'd be expecting myself a TOUCH more out of them. But maybe that's just my personal view. Just thinking when the production car guys can go lap after lap after lap on stock brakes (yes with less power and aero, but a LOT more stops in a row). Just my thoughts on it.
Have alot of bracing on std front subframe now and chromoly version is in the works. R33 oem tie rod ends have become a consumable
Its like anything. Balance. Ask an aero guy putting brakes ducts in theyll throttle you. Brakes guy wil need ducts. Engine guy. Need more air for cooling but the aero guy is gonna kill you. Its all a balance
We are talking about running these at max limit of everything for one lap or two
Like ive said previously, these did the job enough yes, but also tryna push some more now and id rather not f**k around and find out trying to brake at the 50m mark not the 65m mark and it gone wrong type thing
Yeah look at 600hp and 80% braking in a race i could prob get 3 decent laps out of it as is. Maybe more. Ive never raced.....
Regardless the rears are / were std 34 gtr 30 yrs old brembos with a single piece rotor. Thats just not going to be optimal
then you throw into the equation the the tyres are only really good for 1 lap.. tops 2 (but always proven not as fast all things being equal)
Then you put everything together above as discussed and you get to a decision. And this was mine
I used to look at the topish time attack cars and honestly used to think all this was more simple and sort of black and white buy good expensive stuff, this and that and race but as always everyone does things differently and not everything is that easy and works that way. Im trying to listen and follow those way more experienced than me rather than guessing anymore
Either way, by no means am I saying im special or awesome, I put some of what Im up to and all this out there for people to see and read where usually unless you know the person or workshop with a car like this you dont get to see or hear alot about the happenings most of the time. At least I havent
Opnions, questions and debates are good and welcome
Edited by bcozican
  • Like 5
f**k this is an epic build, not much left on the table now surely. More carbon/less weight and correctly located ballast and even more aero is all I can think of. I love how it's gone from a pretty decent Sprint/club day car to full bonkers in a short space of time.
Did you just load Brad's tune into your ABS? I'm hoping I don't have to think about it too much. On another note, I thought Motec were price gouging when they charged $500 for a UTC but they are rookies compared to Bosch. $1800 for a tuning cable? Jesus.
Do you have any in-car from WTAC 23?
7 hours ago, GTSBoy said:
You can get away with smaller (less than you'd want) brake ducts with a little water spray added into them. Only need a super mister nozzle, a little pump and small bore tubing to get enough water to take the sting out of the brakes. Make friends with the aero guy again.
Something similar was actually discussed not long ago as well as a spray into the cooling system
Thanks mate, sorta just had a crack. Why not. Pretty much proper pedal box and flappy paddles maybe and refine
Yeah mine came over with setup in it from my data and other stuff then got refined when he was here
Lol 😅 yeah did see the bosch situation... not great no thanks
Wtac '23 ...Have my fastest hotlap that I put up on my iface page and the lap after that. Everything else disappeared somehow but wasnt that special anyway
Dont know whoe to put it up on here coz im technologically challenged hahaha 😆
Oh righto, I'm not on Faceballs so haven't seen it.
You're not still running a booster and Nissan master? I've got a Tilton setup in mine, it's a bit shit when pads are cold because it's unboosted an a 7.5:1 pedal ratio but once the tyres and pads are hot it's magic. Super easy to get the bias right with pressure sensors too, we set mine by the pressures as recommended by my Motec boffin and it was perfect straight out of the box
  • Like 1
No running a bmc replacement under bonnet. Pretty much a pedal box with individual masters just using std pedals and have bosch accelerator pedal foe dbw also
Does the job but def not the best... but like verything itsnon the list on the list. Maybe next year if I win lotto
Edited by bcozican
  • 1 month later...
9 minutes ago, couchboy said:
Hey mate just out of curiosity what front swaybar do you run and do still use the factory end links if you don't mind sharing that info.
Oem std front sway and new oem end links mate
Rear recently moved to 24mm whiteline sway using the links that came with that
  • Like 1
  • 3 weeks later...
FYI if interested
Brake rotors got taken down to 389mm for clearance and all things adjusted accordingly #bolton
Had a quick retune of the retune to change the VCT window plus some of this and that
Took 7 weeks for me to get a barrell of fuel to run my car on the track = W.A
Actually attempted to drive this thing on the track after 6 months when this shouldve really been 3 monthly ago
Only a few laps - stuff didnt go right because electronic aids in the car mean you drive it a certain way when its indicated they are on and they are actually not things dont go great quickly - car fixed and refreshed + thats been fixed with additional warnings and other thing built in now
Noted - even mucking around at prob 60 - 70% the aero was now hitting the ground where it hadnt previously at 100% plus the balance of the car is improved - hence without shock pots etc etc you can tell the new aero additions have done something reasonably significant
Suspension out - change the bumps and some packers
Tried to go out again - lightning and thunder storms / rain in Perth for the  first time in 50 years for the hour I had - didnt get out
V8SC are now here so no track time at Barbs for many weeks - an going to try go down to our other track a few hours away and try to get in the seat
Got the below as a pressie recently - yes I dont mind the odd lego + this is very good I think and if not into lego even can appreciate someones craftmanship of this level
NissanSkylineGTSTR32TimeAttackRacecarBlack5.thumb.jpg.746b975629a0f7788c91e8fbd4aa9489.jpg
NissanSkylineGTSTR32TimeAttackRacecarBlack4.thumb.jpg.1df1308274e556442c1fdc37f0f5605f.jpg
Edited by bcozican
  • Like 6
Damn thats cool.
  • Like 1
1 hour ago, PranK said:
Damn thats cool.
Genuinely 👌
Custom 1300 piece 1:16 (i think) scale of my car based off pics etc with full instructions and packaged etc using genuine LEGO
Guy in Poland - SPLineup on the www. 😉 or insta
Wife did it as surprise said good experience dealing, took 6 months first correspondence to receipt of product
Edited by bcozican
  • Like 1
31 minutes ago, bcozican said:
Genuinely 👌
Guy in Poland - sp line
Its even cooler now. What a job!
  • Like 1
1 hour ago, soviet_merlin said:
Are you going to be at WTAC this year
@bcozican?
Just realised it's coming up end of August so not long to go at all.
https://www.worldtimeattack.com/
Hey
Yeah ill be there !
Hussling hard now to get seat time and make car all good  see if can get some early track time over east
Itd be really nice to have some luck 😁
Edited by bcozican
  • Like 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
