Will need a 1km headstart, actually it's got some sort of linglong runflats on it. Make that a 2km headstart and it'll blow everything away.IMG_20190818_140611.thumb.jpg.fe0290def2078d6c36780744730c25f9.jpg
Or i could just bring a real car along.
From recent sau Sandown track day.
71153225_2997696350256721_8676391832696913920_o.jpg.ffa2969ea5752ae5a7ea19f29f2f9c1d.jpg
  • Like 1
On 10/25/2019 at 8:36 AM, emts said:
Unless something major happens No.
Time for SAU funded skidpan at Marty's new property.
1) Run private event
2) charge entry
3) claim land on tax for investment purposes
4) ?? deal with bob jane for old tyres, make tyre walls
5 Profit
  • 2 months later...
  • 1 month later...
It should be robust as spec stocks generally trade on futures. Never made sense to me that current prices of oil affect so immediately the share price of a “one day hopeful” explorer.
Lamenting not having sold at 2.6 and bought back in low, but ya just never know with these things. One thing I do know is 1.6 is frikken cheap so I bought a parcel today.
But yes, ASX is a blood bath. Great time to buy blue chips for guaranteed small returns. A2 milk is a pretty safe bet for bounce back as there’s no slowing that company in the long term. Will be $20 before the year end.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
