16 minutes ago, MBS206 said:
Driving on the weekend, air con on full blast, opened a window as dog wanted to get smashed in the face with bugs.
No difference in temp, may as well drop all the windows and run full flow air!
Obviously these guys live further south in cooler climates where AC continues to operate 😛
I'm down south. It seldom gets hotter anywhere else in the southern cities than it does in Adelaide. When we get 40°C, it's usually for a week at a time. My aircon works, and works well. I just don't need/want it in most circumstances. Even driving home from work in the afternoon for 45 minutes, where the air over the road might be 45°C, I prefer the windows down.
In fact, I use it so seldomly that I needed to get it regassed because it all leaked out somewhere and we couldn't find where, and I really should use it every week to keep the seals wet....but I always forget. It's probably been 2 months since I last remembered to turn it on.
I use AC every time I drive the car. Something* makes the car pretty warm simply by existing. It's how I know the car is truly up to temp, water temp, oil temp, cabin temp.
That said it'll be ~22 and keep the temp down on a 40 degree day. There's no excuse for the deletion of aircon. Ever!
  • Like 2
No. It's all Aluminium! :p. And that's the point I'm making, I wouldn't have done it if I couldn't retain AC!
I recently drove it with the center console out, I had thought it was gearbox heat. However after driving it for about an hour, the shifter was still cold and all the heat shielding from the tunnel was working great.
I now think it's the fact that there's headers running behind the steering wheel/infront/underthe driver, and the fact you can feel your ankles warmed when you step out of the car seems to suggest that too.
In any case yeah. Aircon sure is great.
  • Like 2
I seem to recall my VT2 SS with LS1 6 speed getting freaking hot around g/box on long drives. Always assumed it was the box but thinking about it now, there was pacemaker headers either side of it going into twin cats. Greg your assessment of where the heat coming from, sounds about right.
I've got a 10L one, love it.
Also have the basic SCA parts washer, that mostly sits there as an extra work surface but is very handy when needed.
Edited by No Crust Racing
willing to swap your A/C setup for 2 x window switches?
  • Haha 2
10 hours ago, MBS206 said:
So to slightly less de-rail this thread, and bring it back to an earlier, slightly more on topic discussion, Look at what the algorithm is pushing at me...
f**king algorithms...
I'm not willing to click on any unlabelled external link; but I assume it is a hand held device intended to replace a wife
  • Haha 1
Heh. It might be worth it. I turned it on last night because the thunderstorm was causing fogging inside the car. I don't think the compressor came on, meaning that the gas has probably made an exit somewhere. f**ken.
  • Haha 2
Now imagine you had working AC, higher quality of life.
It's safe, I didn't hide it in the quote of someone else :P
it was a link to a Facebook video, advertising Vevor 10L ultrasonic cleaner, and they cleaned 6 pistons while still on their rods in it.
Been driving the 33 to work past couple of days, have clocked up 350km and decided to change the oil and filter. Going to run some cheap mineral oil for the next thousand KMs. Got some nulon 15w 40 premium mineral oil for cheap off eBay. $28 delivered. It arrived today. Looks like Fastway can actually deliver unlike couriers no thanks.
Break in oil came out looking very clean as one would expect. I cut the filter open and was happy to not find any traces off stuff that shouldn't be there. New filter was fitted and oil filled. Noticed a small coolant drip past couple of days, was coming from lower rad hose clamp. Gave it a little more tension, all good again.
Went for another little drive in the arvo, pretty close to 400km done so far. Haven't thrashed it's tits off quite yet, maybe after another 200km.
  • Like 5
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
