5 hours ago, robbo_rb180 said:
Waiting on parts is the worst. Engine bay looks great.
I've got a s14 cable if you want it
Thanks mate. Yeah it's been a long wait but will definitely be worth it.
All good thanks for the offer, ordered a new one from kudos should get here tomorrow.
2 hours ago, Jordy32 said:
Goodness me this thing has shaped up to be an absolute monster lol
Yeah hahah she should get up and boogie now compared to the old baby 2.5 setup
  • Like 1
Got the last intercooler pipe tacked up last night. We'll finish welding it up today and also see if we can do the radiator as well. Manifolds coming back off so we can tighten fittings and make lines up then we'll pop it back on for good.
Also need to go grab some more pinchweld for the hole and trim it out a tad more.
  • Like 6
Got a little bit done on her this arvo/tonight. Went and got the rest of the fittings I needed except a grub screw for the fuel rail. Got cracking on making lines this arvo then pulled the plenum off to give it a final clean and popped it back on. Rail is on as well, just need to run lines up and back and also a vac line to the reg which is half done already.
Tomorrows goal is to get those last lines made, wire injectors and try and get the radiator finished. Gotta cut the middle 2 off and put new ones on and hopefully we can get them to weld nicer. Also gotta put tps plug on when it comes tomorrow and a couple coolant temp sensors somewhere. Then we'll be ready to rumble! Unfortunately won't be here over the long weekend but might try fet back early monday and finish it off if we dont tomorrow.
  • Like 6
Had a pretty good afternoon today... Got all the lines and stuff done bar 1 line from my hardline to my fuel filter which is about 10cm long. Everything else is plumbed up.
Couldn't get radiator to weld so im gonna take it to a mate with a bigger welder to see if he can get it done.
Went through and checked my wiring. Injectors are firing, coils are firing, TPS is good, air temp we need to hook up at ecu. We are getting weird readings from the MAP sensor for some reason.
Also tried to get some oil pressure around the motor but didn't manage to get any :/ Mate said sometimes need to start the motor to get pressure.
Lil vid from cranking the motor, turbo starting to spin without plugs in ;)
  • Like 3
6 hours ago, NEO25T said:
I put a good bit of assembly lube in the pump during assembly, to get pressure up on the gauge it took 5 or 6 5 second cranks of the key
Yeah did a bit of research on it the other night. Gonna pull filter off and try and get some oil down to the pump and turn the motor backwards to get some suction then give it a crank.
  • Like 1
Finished the last fuel line today, checked fuel system and no leaks. Also managed to get the radiator welded up! Doesn't look pretty but it should do the job. We will pressure test it tomorrow hopefully no leaks...
Found a problem with the sensor wiring too. I wired the sensor ground and 5v backwards because the drawings for them werent clear. Those motorsport plugs are terrible to try and pull apart so I've ordered 3 new ones. Will have 2 tomorrow and last one thursday, so will wire up the map and oil pressure sensors and we should be good to fire it up!!
Also tried pushing oil down to the pump but no luck getting any oil pressure still. Hopefully its not the pickup o ring not sealing or something stupid that we'll have to rip the motor apart....
Fingers crossed tomorrow is the day. Won't be able to tune it until we get that last plug for the fuel pressure sensor but will give us some time to double check everything.
  • Like 4
Bit of a shit storm of a night tonight. Got everything wired up so decided to try and get some oil pressure. Gave it a couple cranks but nothing, so decided to try and start it. Everything hooked up checked timing but couldnt get it to go. End up being that the cam trigger wheel was 180* out. Flipped it around and started first go for a couple of breaths and first reading of 5kPa oil pressure! Adjusted the throttle body so we had a bit more idle rpm and off she went! Heaps of oil pressure but had to kill it after a couple seconds as we had a leak from the block. Got that fixed up and fired her back up. Vid below.
Lost a bit of oil from the leak (my fault) so will have to try and get some more joe gibbs tomorrow if we can or im gonna drop it and run penrite run in oil.
Only a couple small things left now, clean up oil from leak, put new coolant sensor into the rad and wire it up, fill with coolant and more oil, check for anymore leaks and then should be onto the dyno if all goes to plan!
Can't wait to see what sort of numbers she does!
Stay tuned
Unfortunately no tuning yet :( got everything sorted though and idles mint! Found a nice leak from the auto, thinking its the pump seal. Doesn't leak until we turn the car off. So gotta rip the box out and go get it serviced this week and hopefully get it tuned before I go away for 5 months the following week.
Couple pics before we started her back up. I put the front end all back together now so looks like a car again!
  • Like 5
Pulled the box out yesterday and had a look. Couldn't see anything standing out that was leaking just the usual leak from the input shaft from the converter fluid. Put some thread sealant on a couple of the bottom bolts. Got it half in yesterday then finished it off this arvo. Turned car on and stillll leaking fml... So over it now, so I gotta pull it back out tomorrow on my bday and have a quick look before dinner. Hopefully theres something more obvious this time. Ill probably end up taking it to an auto shop to have a look on thursday.
You can see where its slowly leaking out of, it must be dripping down from somewhere and leaking through the bellhousing adapter as well. Hoping its just a couple worn seals. Don't think I'll be driving it before I go away on Monday...
I don't know much about that particular tranny but the most common place I saw autos leak from was the outer oil pump seal which is the huge o-ring that goes around the outside of the oil pump to seal against the trans housing.  They're pretty easy to nick the edge off and create a flat spot on the seal when they're being re-installed.  Replace that and your front main seal at the same time and that should realistically fix the leak unless it's leaking from somewhere on top of the tranny and leaking down?  Not a leaky cooler line or something?
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
