5 hours ago, robbo_rb180 said:
Waiting on parts is the worst. Engine bay looks great.
I've got a s14 cable if you want it
Thanks mate. Yeah it's been a long wait but will definitely be worth it.
All good thanks for the offer, ordered a new one from kudos should get here tomorrow.
2 hours ago, Jordy32 said:
Goodness me this thing has shaped up to be an absolute monster lol
Yeah hahah she should get up and boogie now compared to the old baby 2.5 setup
  • Like 1
Got the last intercooler pipe tacked up last night. We'll finish welding it up today and also see if we can do the radiator as well. Manifolds coming back off so we can tighten fittings and make lines up then we'll pop it back on for good.
Also need to go grab some more pinchweld for the hole and trim it out a tad more.
  • Like 6
Got a little bit done on her this arvo/tonight. Went and got the rest of the fittings I needed except a grub screw for the fuel rail. Got cracking on making lines this arvo then pulled the plenum off to give it a final clean and popped it back on. Rail is on as well, just need to run lines up and back and also a vac line to the reg which is half done already.
Tomorrows goal is to get those last lines made, wire injectors and try and get the radiator finished. Gotta cut the middle 2 off and put new ones on and hopefully we can get them to weld nicer. Also gotta put tps plug on when it comes tomorrow and a couple coolant temp sensors somewhere. Then we'll be ready to rumble! Unfortunately won't be here over the long weekend but might try fet back early monday and finish it off if we dont tomorrow.
  • Like 6
Had a pretty good afternoon today... Got all the lines and stuff done bar 1 line from my hardline to my fuel filter which is about 10cm long. Everything else is plumbed up.
Couldn't get radiator to weld so im gonna take it to a mate with a bigger welder to see if he can get it done.
Went through and checked my wiring. Injectors are firing, coils are firing, TPS is good, air temp we need to hook up at ecu. We are getting weird readings from the MAP sensor for some reason.
Also tried to get some oil pressure around the motor but didn't manage to get any :/ Mate said sometimes need to start the motor to get pressure.
Lil vid from cranking the motor, turbo starting to spin without plugs in ;)
  • Like 3
6 hours ago, NEO25T said:
I put a good bit of assembly lube in the pump during assembly, to get pressure up on the gauge it took 5 or 6 5 second cranks of the key
Yeah did a bit of research on it the other night. Gonna pull filter off and try and get some oil down to the pump and turn the motor backwards to get some suction then give it a crank.
  • Like 1
Finished the last fuel line today, checked fuel system and no leaks. Also managed to get the radiator welded up! Doesn't look pretty but it should do the job. We will pressure test it tomorrow hopefully no leaks...
Found a problem with the sensor wiring too. I wired the sensor ground and 5v backwards because the drawings for them werent clear. Those motorsport plugs are terrible to try and pull apart so I've ordered 3 new ones. Will have 2 tomorrow and last one thursday, so will wire up the map and oil pressure sensors and we should be good to fire it up!!
Also tried pushing oil down to the pump but no luck getting any oil pressure still. Hopefully its not the pickup o ring not sealing or something stupid that we'll have to rip the motor apart....
Fingers crossed tomorrow is the day. Won't be able to tune it until we get that last plug for the fuel pressure sensor but will give us some time to double check everything.
  • Like 4
Bit of a shit storm of a night tonight. Got everything wired up so decided to try and get some oil pressure. Gave it a couple cranks but nothing, so decided to try and start it. Everything hooked up checked timing but couldnt get it to go. End up being that the cam trigger wheel was 180* out. Flipped it around and started first go for a couple of breaths and first reading of 5kPa oil pressure! Adjusted the throttle body so we had a bit more idle rpm and off she went! Heaps of oil pressure but had to kill it after a couple seconds as we had a leak from the block. Got that fixed up and fired her back up. Vid below.
Lost a bit of oil from the leak (my fault) so will have to try and get some more joe gibbs tomorrow if we can or im gonna drop it and run penrite run in oil.
Only a couple small things left now, clean up oil from leak, put new coolant sensor into the rad and wire it up, fill with coolant and more oil, check for anymore leaks and then should be onto the dyno if all goes to plan!
Can't wait to see what sort of numbers she does!
Stay tuned
Unfortunately no tuning yet :( got everything sorted though and idles mint! Found a nice leak from the auto, thinking its the pump seal. Doesn't leak until we turn the car off. So gotta rip the box out and go get it serviced this week and hopefully get it tuned before I go away for 5 months the following week.
Couple pics before we started her back up. I put the front end all back together now so looks like a car again!
  • Like 5
Pulled the box out yesterday and had a look. Couldn't see anything standing out that was leaking just the usual leak from the input shaft from the converter fluid. Put some thread sealant on a couple of the bottom bolts. Got it half in yesterday then finished it off this arvo. Turned car on and stillll leaking fml... So over it now, so I gotta pull it back out tomorrow on my bday and have a quick look before dinner. Hopefully theres something more obvious this time. Ill probably end up taking it to an auto shop to have a look on thursday.
You can see where its slowly leaking out of, it must be dripping down from somewhere and leaking through the bellhousing adapter as well. Hoping its just a couple worn seals. Don't think I'll be driving it before I go away on Monday...
I don't know much about that particular tranny but the most common place I saw autos leak from was the outer oil pump seal which is the huge o-ring that goes around the outside of the oil pump to seal against the trans housing.  They're pretty easy to nick the edge off and create a flat spot on the seal when they're being re-installed.  Replace that and your front main seal at the same time and that should realistically fix the leak unless it's leaking from somewhere on top of the tranny and leaking down?  Not a leaky cooler line or something?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
