trust me you arent alone... in early november I had the conversation that the one site is getting updates and they did not realize it, in fact they were using turbos.bwauto.com
unfortunately this type of confusion can happen when there are 12,000+ employees spread across the planet with IT in germany, engineering in north Carolina, Corporate in michigan and billing somwhere else. all part of the fun & games in our automotive aftermarket industry.  too big to ignore, too small to dedicate real resources to.
On 1/9/2020 at 6:59 AM, Full-Race Geoff said:
+1
done this a number of times on different applications.  The results are typically what you would expect, bigger AR makes more power, appears to spool identically (on the dyno).  on the street it loses response
Some tuners who claim this do not have enough data to work from, or a lack of understanding (or both).  Backpressure and shaft speed + EGT are critical links in understanding the system.  If they are disappointed in the max power result then its probably an issue with the setup or the turbo is too small.
The larger inducer EFR 9280 certainly does move more air.  and Peter may be pleasantly surprised with the 9280.  I felt the same in many instances, but so far it appears to be delivering
What data do you have and what tests have you done with a 9280?
Edited by RB335
the best 9280 back to backs against 9180 were WTAC builds from scott kuhner at Emtron / Insight. 3 cars, all the same turbo, shaft speed went down, airflow went up, backpressure did not get worse
RB30 + 9180 + Sequential
955bhp ... must be engine hp as he has 1000cc injectors and one pump so that implies 98 fuel... surely not atw right?
Goes hard but doesn't seem to be that much faster than mine
These guys do some silly stuff on public roads
  • Like 2
I didn’t watch the video I just assumed,
uk dyno their cars at the wheels then make up some number that it makes at the fly wheel usually in lots of 50s and use that number to state what power it makes
  • Like 3
... they also rip on US dynos for "reading high" yet come out with stuff like this, claiming 800+hp from setups which just can't make that kind of power - then post times which don't match the power and make a bunch of excuses.  I remember when they had a couple of serious drag Skyline builds where they were making big power claims but not running as quick as lads down under they even went so far as to claim the drag strips were downhill here and if they ran here they'd be faster lol
45 minutes ago, GTSBoy said:
Is that a trick question?
No , you have a bloke saying he has 955hp car in the UK on 98
Fatz said he has the same , I asked,   on what fuel ?
I think 955hp on 98 with the UK  setup is BS?‍♂️
But I am asking FATZ , a bloke with much more knowledge than I have a question
The only way to learn anything is ask questions, I  work on the assumption that “ there are no stupid questions, just stupid answers”
You have been lured in by the man's satirical comment. He does not have that many horsepowers
Yea I don’t have 950Hp
more like 400rwkw
but my shit heap needs two external pumps 2000cc injectors and e85 to do that shit at 21psI
lol
im sure if I was dumb enough to run 28psi I might have 460rwkw at which point I’ll have 950hp like mr uk... lol except my imaginary 460kw would be faster than his 950
either way internet videos make me laugh and that was a cracker... mainly cause the f**ker in the passenger seat
  • Like 2
  • Haha 1
9 hours ago, Full-Race Geoff said:
people also think dyno #s = drag times.  but fail to realize that gearing, chassis, tire setup, track prep and launch specifics matter quite a lot...
think more important would be lap times cause that typically sorts the “good” turbos from the junk
but measuring that is difficult
  • Like 2
Yeah ?
,Paul already laughed at me for believing Fatz’s  Pisstake comment ??
i am old but stil gullible ?‍♂️?
  • Haha 1
I’m pretty fresh to SAU, I used to follow Supra forum pretty hard. I’ve read through this post from 70ish onwards. Very interesting results.
I have a 3L Supra with GSC S2 cams (272ish), GSC Beehive springs, stainless valves, 9.5:1, all the good gear inside. Bottom end is for 1500hp.
ive has big turbos and want this next iteration to be a great street car. I’m thinking the 8474 with a progressive 400shot at the drags.
Looking at Matchbot, the turbo is too small for the engine, then using logic my goals are a responsive turbo, so I guess that fits.
My question is, will the 9280 be a responsive turbo On the 2JZ or is it a turbo more spec’d for racing where you can swap a cog or drag racing.
I can’t find any 2JZ’s with the 8474... mostly they go Precision. I saw the 8374, which had a nice boost curve.
comments welcome...
Hey mate, sounds like a fun build :) Some pretty ambiguous or open to opinion comments in there so some background on what you've had and where you're coming from would help.
Your previous "big turbos" you've had, what are they are what kind of power have you made with them?   Is this the same engine spec as you used with them?
It'd be good to quantify what an acceptably responsive turbo would be for you, and what "too small" means - as an EFR8474 should be fine on a 3litre depending on how much work you're expecting it to do.   What is the pre-nitrous power target?
Also, a 400 shot of nitrous - I see you like to party.  You may need to be very sure you have enough hotside to support the inevitable exhaust gas flow which is going to result from this combo
Edited by Lithium
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
