R32 4 door to 2 Door conversion?
Experts,
This thread is about a project overseas, not in AUSTRALIA.
I was wondering whether it is possible to convert R32 4 door sedan gts4 to a R32 GTR? (NOT in AUSTRALIA)
If so, how complex will the chassis mods be?
The reason for thinking of this project is, it is not legal in Bangladesh to import any cars over 5 years of age. Hence a R32 can no longer be imported. Only solution is HALF CUT imports. Therefore, I was wondering if we can use the parts from the HALF CUT for a GTR conversion? Moreover, wanted to know whether Sedan to Coupe conversion is also possible? Or does it have to stay 4 door?
Thanks in Advance!
https://www.sau.com.au/forums/topic/467737-r32-4-door-to-2-door-conversion/
The main problem I see is that the coupe door is wider and therefore the pillar needs to be relocated. Secondly unless the job is done to a very high standard you could end up with a death trap in case of an accident. And I have no idea what the regulatory regime is like in Bangladesh. Four door R32s can look cool.
1 hour ago, MarvinsR33 said:
The dumbest thread I've read so far.
Dude, wtf just buy a 2 door GTR32.
This is S(AU) for a reason
You're an idiot
Op
I doubt it is financially viable
But yes it is possible given enough skill and money.
No reason you couldn't just drop an rb26 in the bay and upgrade the brakes etc and make yourself a 4 door GTR
  • Like 3
Mate, that's quite uncalled for, if you actually spend 30 seconds and read the post, he can't import a 32 GTR as the countries laws don't allow it and he obviously has access to a 4 door 32 that's all ready in the country. Unless you have something constructive to say, don't say anything at all.
OP
It would be possible to do, but the engineering required to do it and also the money would make it probably not worth while, it would need to be dead straight and chances are it would never drive and handle correctly.
I think @zebra is onto the right idea, get yourself a half cut and convert the running gear and front end of your 4 door over to a GTR, you will be able to pick up the rest of the various goodies along the way to bring the interior and rear up to spec. i like the idea of a 4 door 32 GTR
Edited by Coullsy
Fixing spelling errors
  • Like 3
@Coullsy, @KiwiRS4T, @zebra Thanks heeps. I was thinking along a 4 door 'GTR' conversion all this while. Just wanted to get more info from you guys!
@MarvinsR33 dude I have a 94 R32 GTR in AUS. Like I mentioned in the thread, it is not possible to import these into Bangladesh.
This comprehensive R34 sedan to GT-R conversion will give you an idea of the effort required, it's pretty insane:
http://www.carscoops.com/2016/09/nissan-skyline-r34-gt-r-gets-4-door.html
The pillar is just one problem. AFAIK:
  • Front window rake and glass is different
  • Rear window rake and glass is different
  • Floor pan is different
  • Door cards are different (obviously)
  • Rear interior, seats and parcel shelf are different
  • The boot, in fact the whole rear end (including tail lights) is different (see photos on above page)
  • Exhaust system is different
etc. etc.
It's totally not worth it.
However, what IS worth it is a sedan with GT-R running gear. A much cheaper proposition too - do it!
Not sure if it's option or just stupid.. but put the 4door neck together but weld the doors and make it flush to make the appearance of a 2 door?
I know it happens with other cars in Indonesia. Not sure if it'll look funny though.
Just an idea :)
If You're happy with the 4 doors then it'll only be possible with an accompanying SAU build thread. :)
Hey@marvinsR33 keep that crap out of this site please mate. Not interested in reading that drivel.
@V28VX37thanks heeps mate!
I will definitely go ahead with a 4-door build. When I do, will definitely start a thread to seek help from you lot. Unfortunately won't be very soon as I just moved to AUS.
Thanks everyone for your knowledge.
  • Like 1
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
