4 hours ago, Adzmax said:
I picked up an R200 with a 4.4 LSD on the weekend, I'll strip this down and rebuild it along with the rest of the rear end in the coming weeks.
7 Days for a update bruh, whats happening :P
In all seriousness, take your time, build is looking awesome :D
7 hours ago, jmknights93 said:
Such an awesome thread. Loving these updates :)
Thanks mate!
Some goodies we purchased in Japan at Nostelgic 2 Day arrived today (no pun intended), a set of S.E.V Marchal headlights.
  • Like 2
It's been a pretty crazy few weeks so not a lot happening on the car front, hoping to reassemble and pain the GTR grill this weekend though. I can't for the life of me find the paint sample we made up so I had to get a mate to send me down his colour chips for matching, no paint codes available for this stuff unfortunately.
I was going though some boxes from my trip to Japan in Feb this year and found these goodies. Some door handles, a GTR style gear know, NOS badges, water heater seal and stainless trim for the centre console.
Also a whole bunch of stickers for the car, it's the little details that make the difference! :)
  • Like 2
So a pretty major development this week, Lachlan Fowler at Les Collins Racing had a fully built 3.3ltr L series short block for sale which I've purchased. He's decided to go down the full billet crank race spec path meaning the built bottom end is no longer needed. I'll supply my own P90 head to the builder to be ported, polished and rebuilt. The motor should be good for 350hp and 280ft'lbs of torque with the right head, cam and induction.
Short motor specs are:
  • L28 3.3ltr short engine.
  • 89mm bore x 89mm stoke = 3322cc
  • Engineered by Les Collins
  • F54 block. Acid dipped, 1/2 grout fill, sonic tested & offset bored to 89mm & finial diamond honed to exact clearance.
  • Deck milled parallel to crank tunnel centreline.
  • Clearanced crankcase, de-burred & painted in Gyptal.
  • New gallery plugs. Blanked oil pressure relief port.
  • Standard sump & pickup (to be replaced with Kameari pickup)
  • Modified 89mm stroke crankshaft, oil gallery plugs tapped & plugged.
  • Custom CNC billet steel 8.8kg flywheel to suit crank (no clutch assy).
  • 137mm I-beam connecting rods with ARP2000 rod bolts.
  • Custom SPS 89mm forged pistons – designed to work with a P90 head.
  • New timing chain guides & new Kameari HD timing chain.
  • New OEM front timing cover (de-burred, polished & water-jet blasted) fitted with replated bolts.
  • New Water pump.
At this stage I'm looking towards injection as the 44 Mikuni carbs I have just wont be big enough and would limit the motor to around 280hp. The other option is 47mm OER carbs but Jenvey make a 47mm heritage DCOE twin body with the injectors hidden in the body. Heritage look with modern features. I'll need to look at a fuel tank conversion using EFI hardware's EFI conversion kit and consider an ECU, perhaps Motec M800 or a Haltec equivalent.
Not sure who will complete the head work and engine but at this stage I'm looking at either Peter McDonnell or Les Collins Racing, both are true professionals and will do a great job.
Here are some shots of the motor before it will be torn down:
  • Like 2
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
