1 hour ago, BakemonoRicer said:
Are you aware the CD009 will become the lowest point on the car? They hang a LOT lower than the chassis rails, just an FYI.
What you need is a Samsonas.......
lol... fuark the peer pressure is real, also my car isn't that low (as you can see in the photos).
38 minutes ago, BakemonoRicer said:
Paintjob looks mad.... did you take the strut towers off to do a rust repair while engine out?
E.g.
http://blog.garage-yoshida.net/wp-content/uploads/2021/02/IMG_0100.jpg
http://blog.garage-yoshida.net/wp-content/uploads/2021/02/IMG_0099.jpg
We sanded the towered back to bare metal around the rust areas, wasn't as bad as those photos. Hit is mum with rust converter and re-sealed, then painted over.
For real, I am currently shopping for a very expensive gearbox while my clutch is out. (???? cars...)
Buy once, cry once, then enjoy the benefit.
That said is there actually any benefit with a Samsonas for your intended use 😛
Can grab another gear mid drift at Powercruise and look like a sik karnt :D
But no.. I will not Samsonas my car.
  • Like 1
But how can this should work at all ? . . . . .
Easy samosa recipes to cook at home during lockdown
2 hours ago, dr phil said:
Somebody please do a BMW DCT conversion. There is a GTR kit now for the transfer case too.
I looked into this for the LS! It looks like there's an adaptor plate for the LS, and the gearbox itself....
... and nothing else. No easy to find dimensions/sizes of things, no electronics,
Noone sells the rest of the 'kit' to make it actually 'work'.
But I wish they did >.>
I'm looking at this for the Silvia using HGTs stand alone. It "appears" on paper to not be that much more than CD009 conversion, but obviously with a little more work/complexity.
As my car will only be a little 4cyl, I am hoping I can get away with the ZF8HP70 or 75.
Flappy paddle last minute corner entry/exit changes would be pretty hektik though...
  • Like 1
Very sex, this is why you see M2/3/4s at Wakefield just fly out of the fish hook, all the manual boys trying to rev match, shift dis dat, they're just cycling through the gears and flying out.
  • Like 1
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
