G30 turbine flow :
Les turbo garrett G series - Page 4 G30turbineflowmap
G35 turbine flow :
Les turbo garrett G series - Page 4 G35turbineflowmap
The compressor flow chart :
770 :
Les turbo garrett G series - Page 4 G30-770comp-map
The 900 one :
Les turbo garrett G series - Page 4 G35-900comp-map
and finally the 1050 one :
Les turbo garrett G series - Page 4 G35-1050comp-map
All were taken from ATP website so I consider these as legit but still take these with a grain of salt as they were not officially released.
Understood, and very much appreciated - thanks for sharing - that's awesome.
I'm pretty confident they are legit, btw.  Just probably weren't meant to be released yet
I've had a quick play with that data, and if I am looking at it right - the 1.01a/r G30 hotside is very comparable to the 1.05a/r EFR8374 hotside which puts things into perspective.
The .83a/r G30 hotside falls slightly short of the .82a/r GT35 hotside in flow.   I think Garrett have chosen some very nice spread of options with this range.
  • 4 weeks later...
On 12/04/2019 at 4:41 PM, Phat_Toni said:
The g25 660 with the 0.92 looks comparable to the GT3076r but seems to have the edge in turbine flow, compressor flow and spool.
g25 660 0.92 from ATS
6boost mani
I saw a post on Sinco NZ's Instagram page which made me think of you, how is your build going?  Did you end up going Sinco for the manifold or is there someone else doing similar?
1 hour ago, Skylineusa said:
This page is gold with great information. Thank you guys! Would running twin 550 be a worthwhile combo?
That's a very open ended question.  For what power target and on what kind of setup??  Do you have the budget and inclination to do all the fabrication to do twin 550s? (it's not something you'd do on stock manifolds/location).
It is the kind of setup which to justify would need a pretty solid engine spec, basically its a 1000hp turbo setup so expect the kind of lag that would come with one and expect to need to do the kind of engine and transmission development needed to support it.   If you are looking at making the typical kind of power that people go for with low mount twins then no, imho it is not worth doing.
5 minutes ago, Phat_Toni said:
I think this car was mentioned earlier in the thread. Gives a good idea as what to expect from 2 of these things....
It's worth nothing a couple of things he says which contradict each other, he implies it spools 500rpm better than the EFR9180 but then also says its all in between 6000-7000rpm which on a 2.8 is... umm... much laggier than any EFR9180 I've heard of.
It's been previously said that it's got a 500rpm wider powerband as the 660s hold on (unsurprisingly) to much higher rpm than the EFR9180 and other turbo setups they ran on it, so if you are willing to rev it to 9000+rpm then it offers the potential to give a broad delivery - as long as you aren't hoping for things to happen earlier in the rev range.
Be great to get some more data points from that car.
The twin G25-550 intrigues me as well.  They do the internal gate T2 .49 which screams bolt me on an RB26.
I've be told by a seller its not a bolt on affair though. I was not given any details other than you have a 30 year old car "dude" as to why.
The cost of them makes it a serious investment and a risk you end up with a street pig.
If not and they make 900-1000fwhp with amazing spool  ..... all the glory is yours  ......
When they released the spec sheet on the g25 I looked at them real hard. The problem I saw is they are longer than the stock turbo. There just doesn't seem to be horizontal room for them. Granted this is based off the spec sheet and not trial and error.
If we could slant them 20° from horizontal they might fit but you can't do that and expect the snail to live.
Sorry Lithium, you are correct. I should have gone into a little more detail. I was thinking for quick spool, which I understand by your reply, and looking at the map, would not be a good marriage. It looks like I will wait for the 770s to come out, and go that route.
Hypertune makes twin manifolds for the G25s, if anyone is going that route. My car is more street than track, so I really do not need that much power.
Edited by Skylineusa
I hope you mean a single 770? :o
  • Haha 1
Yeh its interesting.
I am in the process of getting rid of my HKS F-con rubbish in favour of a Link g4+ and upgrading my trigger system and fuel system at the same time.
Once done the G30-770 be on the next list to replace the -5's.
So sooner they come out the better so someone else test for me.
  • Like 3
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
