G30 turbine flow :
Les turbo garrett G series - Page 4 G30turbineflowmap
G35 turbine flow :
Les turbo garrett G series - Page 4 G35turbineflowmap
The compressor flow chart :
770 :
Les turbo garrett G series - Page 4 G30-770comp-map
The 900 one :
Les turbo garrett G series - Page 4 G35-900comp-map
and finally the 1050 one :
Les turbo garrett G series - Page 4 G35-1050comp-map
All were taken from ATP website so I consider these as legit but still take these with a grain of salt as they were not officially released.
Understood, and very much appreciated - thanks for sharing - that's awesome.
I'm pretty confident they are legit, btw.  Just probably weren't meant to be released yet
I've had a quick play with that data, and if I am looking at it right - the 1.01a/r G30 hotside is very comparable to the 1.05a/r EFR8374 hotside which puts things into perspective.
The .83a/r G30 hotside falls slightly short of the .82a/r GT35 hotside in flow.   I think Garrett have chosen some very nice spread of options with this range.
  • 4 weeks later...
On 12/04/2019 at 4:41 PM, Phat_Toni said:
The g25 660 with the 0.92 looks comparable to the GT3076r but seems to have the edge in turbine flow, compressor flow and spool.
g25 660 0.92 from ATS
6boost mani
I saw a post on Sinco NZ's Instagram page which made me think of you, how is your build going?  Did you end up going Sinco for the manifold or is there someone else doing similar?
1 hour ago, Skylineusa said:
This page is gold with great information. Thank you guys! Would running twin 550 be a worthwhile combo?
That's a very open ended question.  For what power target and on what kind of setup??  Do you have the budget and inclination to do all the fabrication to do twin 550s? (it's not something you'd do on stock manifolds/location).
It is the kind of setup which to justify would need a pretty solid engine spec, basically its a 1000hp turbo setup so expect the kind of lag that would come with one and expect to need to do the kind of engine and transmission development needed to support it.   If you are looking at making the typical kind of power that people go for with low mount twins then no, imho it is not worth doing.
5 minutes ago, Phat_Toni said:
I think this car was mentioned earlier in the thread. Gives a good idea as what to expect from 2 of these things....
It's worth nothing a couple of things he says which contradict each other, he implies it spools 500rpm better than the EFR9180 but then also says its all in between 6000-7000rpm which on a 2.8 is... umm... much laggier than any EFR9180 I've heard of.
It's been previously said that it's got a 500rpm wider powerband as the 660s hold on (unsurprisingly) to much higher rpm than the EFR9180 and other turbo setups they ran on it, so if you are willing to rev it to 9000+rpm then it offers the potential to give a broad delivery - as long as you aren't hoping for things to happen earlier in the rev range.
Be great to get some more data points from that car.
The twin G25-550 intrigues me as well.  They do the internal gate T2 .49 which screams bolt me on an RB26.
I've be told by a seller its not a bolt on affair though. I was not given any details other than you have a 30 year old car "dude" as to why.
The cost of them makes it a serious investment and a risk you end up with a street pig.
If not and they make 900-1000fwhp with amazing spool  ..... all the glory is yours  ......
When they released the spec sheet on the g25 I looked at them real hard. The problem I saw is they are longer than the stock turbo. There just doesn't seem to be horizontal room for them. Granted this is based off the spec sheet and not trial and error.
If we could slant them 20° from horizontal they might fit but you can't do that and expect the snail to live.
Sorry Lithium, you are correct. I should have gone into a little more detail. I was thinking for quick spool, which I understand by your reply, and looking at the map, would not be a good marriage. It looks like I will wait for the 770s to come out, and go that route.
Hypertune makes twin manifolds for the G25s, if anyone is going that route. My car is more street than track, so I really do not need that much power.
Edited by Skylineusa
I hope you mean a single 770? :o
  • Haha 1
Yeh its interesting.
I am in the process of getting rid of my HKS F-con rubbish in favour of a Link g4+ and upgrading my trigger system and fuel system at the same time.
Once done the G30-770 be on the next list to replace the -5's.
So sooner they come out the better so someone else test for me.
  • Like 3
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
