But if reversing cameras are banned then what are the 3T trucks with no windows gonna do?
And what are the panel beaters gonna do when Suzy learns how to park properly? Or Shane finally gets used to how close his garage door really is?
You gotta think of the future GTSBoy
I am thinking about the future.  I'm thinking of a future where everybody looks like the meat pillows in the Wall-E movie.  They're almost there now.  Can't do a google search without having Siri or Alexa stand between you and the nasty internet to handle your query.  Can't buy anything if it involves using a phone as a voice communication device - has to be on-line.  Can't navigate the roads of their own city without eyes glued to the blue line on the phone screen at eye level above the dashboard.  Can't cook, have to use Uber-eats.  Can't reverse a car without beepy sensors or screens showing alignment lines, or worse, auto f**king self parking faggotry.
/rant
Every time I hire a car it takes about a week before I notice that the thing even turns a camera on and shows a blurry f**ked out view of what's behind me when I engage reverse gear.  That's because  I'm already doing the right thing by looking backward before I engage reverse to make sure there's nothing behind me.
This isn't a disucssion about the need for reversing cameras (they have been legislated in the US to be on every passenger car from 2018 on.)
https://www.autotrader.com/car-news/new-backup-camera-rule-cameras-will-be-mandatory-by-2018-223739
As for the post you quoted, it no longer exists. :(
  • Like 1
I've seen several options on the market for R34 that replace the rear license plate light, so that it works/looks relatively OEM.
I've been trying to source one for a while, but the only ones I've tracked down don't have any side marker lines on the image  - which is something that's overlayed in the camera.
In the past, I'm fairly sure that Carbon Car Systems and Chris Rogers have been able to supply similar, along with MFD integration if required (not relevant to GTT)
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
