All,
I've picked up a set of GT2860-7's for my R33 GTR and looking at swapping them out myself (yes have read through the pleasure that this will be).
Am after some advice on the following:
Thanks in advance.
Links
https://www.sau.com.au/forums/topic/478921-changing-r33-gtr-turbos-advice/
Curved scanners are bloody helpful! Help you get to some of the turbo to manifold bolts that are hiding around corners.
Uni joint sockets are a must.
A couple of things to do while you’re at it are replace your manifold studs and fit braided lines. Piss the hard lines off. Makes life soooo much easier for refitting and removing next time.
Good luck!
Great - thanks for that, exactly what I wanted to know.
Will look at getting the stud kit then and replace those and save having to do it again. Re: Braided lines - good thoughts - something like this I assume - https://www.ebay.com/c/651282471
Cheers - might need it, or just some patience!
Also get plenty of wd40 etc on the studs and hard lines for a couple of days before.
The biggest (unexpected) thing is normally studs failing and snapping, so if you can have them freed up as possible before you start it will really help. Once a stud has given out you might be lucky and able to get it off with whatever remains, or you might have to drill and easi out it which is where the job turns into a disaster. Heat /blow torch can really help if you don't like how it feels when you are undoing it.
The hard lines often won't free up from the banjo properly so they turn with it an eventually snap, so like Ewan said aftermarket braided lines handy means you don't have to worry about that.
Good luck mate!
Thanks Duncan - yeah the studs snapping is on my mind - good advice to get some WD40 on it for a few days leading into it and just taking it easy. Will factor that in definitely.
Sounds like braided lines are the way to go.
Thanks - the good luck's piling in...
For farks sake mate, WD40, CRC 5.56 ect is fine in a pressurised can so you can spray it, and what MOST mechanics who work on these jobs to free up the nuts and bolts will use in the real world.
  • Like 1
Good luck!
This. I still remember the nut in the corner of the rear turbo. Probably took me 1/2 day to figure out how to get it off. In the end i bought a small spanner(i think 12?) and grinded the corners. Also, not a big thing, but lining up the water/oil lines was a bit of a pita as well.
If you have friends it would def help. Also look at replacing all the gaskets and washers at the same time. Personally, if i was doing that again, I'd rather pay someone!!! Its a fkn pita, esp in a tiny garage on axle stand only!
27 minutes ago, Dose Pipe Sutututu said:
Feel free to ignore.
Replace it with a single twin scroll turbo, because you're going to eventually put a single on it.
I used to argue this. Now I don't and I haven't even driven it yet!!
The simplicity of the single is a definite advantage.
23 minutes ago, niZmO_Man said:
Stubbs are great but if you don't have them already get the two different types of curly spanners. Not useful till you need them then they become life saving!
To do this job I’ve got s shaped spanners, crows feet, 1/4, 3/8 and 1/2 drive socket sets with lots of various length extensions, rattle gun, ratchet ring spanners, normal spanners, offset spanners and the list goes on.
I have doing this job down to art now but I was a mechanic and am lucky enough to have a very extensive range of tools at my disposal
I’ve also seen more then my fair share of people who have f**ked this job attempting it
Perfect, sounds like you’ve got all the right stuff!
Doing a rough count in my head I have 14 sets of different spanners, possibly more. I feel I may have a sickness...
2 sets of cheap metric I use most of the time
1 set of long shank
1 set metric stubby
1 set metric stubby ratchetting
1 set normal length ratcheting
1 set metric double ring
1 set imperial double ring
1 set imperial standard spanners
1 set metric S spanners
1 set metric C spanners
1 set crows foot spanners
1 set I keep in my Ute
plus I think there’s a set of stubby imperial spanners out there somewhere!
Most of them are cheap shit apart from a few.  I sold my snap on stuff years ago when I got home from the tools and needed money to fund a stupid lifestyle....
This wasn’t a dick swinging contest but would be curious if anyone had any more than that for a non commercial setup! ?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
