Stagea Wheel Dimensions?
Will the below wheels fit a late model Stagea?
Front - 19" x 8.5" (30 mm offset) 245/35/19
Rear - 19" x 9.5" (30 mm offset) 265/35/19
no.
you need to match the rolling diameter of the tyres on the front and the back at all times. so, the closest match ive found for 19s is a 235/35/19 on the front for an 8.5" rim and a 275/30/19 on the rear for a 9.5" rim. there is only about 3mm difference in rolling height between the two. that info is from the official tyre standards book i have at work (im a tyre fitter)
D.
no.
D.
Thanks D.
Is that the only reason they won't fit? What about physical dimensions around the guard/brakes/suspension?
I had these on a 350z Track and the traction control requires very specific rolling diameter front to back and apart from the 275 rear you suggest (which i was originally after, but difficult to find in reasonable price tyre that matched the front) the next best option by mm's was 265.
i haven't had a chance to try those sizes on my car yet but i'm assuming they will a tight fit physically, my car is also a manual so i require different offsets to autos. as long as the offset is good then brake clearence wont be an issue.
ill check rolling diameters on 265s tomorrow but it would definately need to be a 30 series to be anywhere close to matching a 245/35... il see what i can find but from memory, the only thing close enough to a match was the 235/35 and 275/30
D.
edit: oops, meant to be in reply to last page... see http://www.skylinesaustralia.com/forums/in...t&p=4559953
Interesting; I have those exact same rims (R33 GTR I mean) on my series 2 with standard suspension, no spacers. They sit pretty well too I think... 245/45/R17.
re. KiwiRS4T:
I agree - that's right, tyres are not wide enough at 245... but anything wider than that in tyres is sooo darned expensive... even at 17's. I calculated my tyre width as being about right at 245mm with 9-inch wide R33 GTR wheels (245mm ~= 9.6") but alas, evidently I did not allow enough for the lip/beads/whatever, and they are stretched but only a little. Tye fitter told me about it and said it was ok but that I would get a little premature wear on the edges.
Edited by DaveB
ok, got some sizes here.
for 19'' tyres with 35 series profile- all will fit an 8.5" rim legally
215 - 633mm
225 - 641
235 - 647
245 - 655
255 - 661
265 - 669
275 - 675
30 series- all will fit a 9.5" rim legally
255 - 637
265 - 643
275 - 649
285 - 655
so, closest matches are 225/35/19 and 265/30/19 only 2 mm difference between
and, 235/35/19 and 275/30/19 only 2 mm diffenence
BUT
235/35 and 275/30 are nominal sized tyres for 8.5 and 9.5" rims
the other sizes will fit legally and safely but the nominal (reccomended) sizes are 235/35 and 275/30
hope this helps people out
D.
I think your rears might be close to the struts. I currently have 19 x 8.5 + 20 rims on my car front and rear. I have about an inch of clearance from the inside of the rim to the rear strut. With an inch wider rim and also the 10mm difference in offset it will be close to the strut tower. If you can test fit the rims I would check this for sure to make sure you have enough clearance. FYI mine is a manual version so has slightly different rear end setup so it may not be an issue with your car but it always pays to check.
Edited by StageaTypeS
Hi everyone, newbie here with a boring question but info on stageas seems hard to come by. Anyone know what the standard tyre fitment is for 2001 (M35) stagea. Has standard factory 6 spoke 16inch wheels. Current hard and cracked tyres look like prob originals from japan 205-65-16. Did quick measure rims look like 6 1/2 inch. Judging by our websites here in NZ that looks like an oddball tyre size, not much selection available. Any recommendations for4 average driving but something a little bit extra grippy like Re001's etc... Thanks
Standard fitment should be on sticker inside wall. I am using Re001 235/45/17 - used to have 215/55/16 on my last set of rims - look for a set of V35 17in rims if you don't have the cash for Rays just now - they will look good and stock at the same time.
Tired after work - meant to say sticker should be on inside of drivers door on pillar.
Your tyres are not wide enough. I guess you are going to get wider ones when you "adjust" your wheel arches (quote from Yokotas13 "baseball bat is your friend") but some people seem happy to run with "stretched" tyres which will not handle as well as properly fitted tyres. It appals me but for some it seems a kind of fashion statement!
What a load of old tosh. 235s on a 9 is no stretch, its barely any tighter than a perfect 'square' fitment. The big sidewall protectors most modern tyres have makes them look as though they're pulled tighter than they are. There'll be no disadvantage to the handling there.
Now, if he had 10s or wider...you might have had something to carp about.
Tosh? Tosh? Possibly my fault for making two points in one post. Califunky's tyres are not wide enough - 235s on 9in rims may be acceptable according to the charts but looking at the photos with this particular tyre/rim application they are not square enough for my liking but certainly not bad enough to ditch - I too would want my money's worth out of the rubber..
but I have seen other people (not Califunky) with ridiculously stretched tyres - possibly to fit under guards or because they bought the wide rims but find they can't afford the stratospheric prices for the rubber to go with them. i guess it makes sense for the drifters because they are after controlled power slides so want to lose traction and grip ( opposite to the norm).
p.s reference to baseball bat was a joke - I wouldn't use one on my car either but with Yokotas i am not quite sure whether or not that was in jest!
For M35 16" wheel, OEM size is 205/65R16 with 95 load rating and S speed rating. Should be dirt cheap to replace...
:D
You sure bud?
AR-X should be 18's.
My RS is 215/55R17, 7" wide.
Can't remember the load & speed rating, but it was different to my mate's RS :)
I believe that the 16's came on the 250RS (RWD N/A)... and looked crap in those huge wheel arches!
Ah yes, us Aussies with our Turbos get the 17s on RS/RX and 18s on the AR-X, but the Kiwi's can have a NA 2.5 Direct injection which comes with 16" wheels on both 2wd and 4wd RS and RX models.
And in 2wd, they also only get a 4 speed gearbox...
You sure bud?
  • 4 weeks later...
hate to revive an old thread but the question seems a better fit here than other or a new thread:
will wheels off a 350Z fit an M35 stagea?
while I'd like to go to 18's these are for sale and look great:
Fronts 17 x 7 1\2 inch
Rears 17 x 8 inch
Comes with Set of Bridgestone Potenzas - Not Fitted
225 45 R17 x 4 70 - 80% Tread
Rears 17 x 8 inch
Offset?
If you are getting bigger brakes, don't bother with these. You will never fit them over the larger calipers.
Stock RS wheels are 17x7 so these will easily fit if the offset is satisfactory.
One last thing. Try to keep the wheels and tyres the same size all round.
I know the Z33's and V35's of the world generally have wider rear tyres, but that is because they are RWD cars.
Does anyone know if 17x9 will fit on the back of a s2 rs4 with stock brakes and suspension, will be geting lowered 25mm at the same time.
Probably put either 245s or 255s on the rear
