Sweet. So you bought just the mid pipe section?
Anychance of a sound clip?
Couple of pics of the two mid pipes next to each other, for those interested.
post-20696-0-75204800-1329877377_thumb.jpg post-20696-0-41664500-1329877391_thumb.jpg
And a sound clip...
VN_20120222_00001.mp3
Nice Nick!
Can you make some magical forged rods and pistons that go in through the plug holes for me...?
My old mechanic rebuilt an engine for me from under the car through the sump, without removing the engine. Does that count? :whistling:
And a sound clip...
Cool. Thanks for the pics and sound clip. Sounds like it has more of a throb at idle. I'm on the hunt for one.
I've had this http://www.ebay.com.au/itm/MISHIMOTO-RACING-RADIATOR-12-FAN-SHROUD-03-06-350Z-Z33-VQ35-MMFS-350Z-03-/310378082783?pt=Motors_Car_Truck_Parts_Accessories&hash=item4843f9b1df#ht_2521wt_956
and this http://www.ebay.com.au/itm/110822338664?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_3225wt_907
and this http://www.ebay.com.au/itm/120858143293?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
turn up today....hoping to get in in by the end of the weekend and hopefully it fits without to much modification to my race radiator.
got a bit of a power gain in the top end with that big POS fan gone.....motor is a lot smoother to......nearly as smooth as an RB20DET.
still waiting in anticipation for my new front and rear bars!!!!
What new bars are you getting Craig?
A custom one on the front(in other words I cannot figure wtf it is) and Kenstyle on the back.......and I am flaring the front fit in with the front guard!
It's a custom modified kenstyle front - one of a kind for sure!
Pictahs? Not that I can see them at workbecause all photo's are blocked somehow!
thats what it looks like to me as well.........I just hope it handles the flares.....was also thinking of going with a Matt Black vinyl for the front bumper!
I might also set it up as a quick release bar
I've had this http://www.ebay.com....f#ht_2521wt_956
and this http://www.ebay.com....9#ht_3225wt_907
and this http://www.ebay.com....984.m1439.l2649
Did the shipping really cost almost $600 for the fans?
Cool! Can't wait to see this!
wrote it off...
That's a bummer mate :O . It wasn't 'cause the chassis got caught on the line markings & threw you off the road....?
lol good call
looks like its the pink ones that like to die early in life!
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
