Finally got my gas struts regassed today; no more getting belted in the back of the head when I throw backpackers in the boot.
Guess I'll have to get a bat or something to knock them out now.
This has been on my To-Do list for, oh, about 5 years now...
Nice!
Can you get the sedan in a manuel, or are they all auto?
7-speed auto in the KV36 with the 3.7 motor for JDM, but the US got a 6-speed manual... :-) But I do have flappy paddles now!!
looks good smile.gif I'll have to have a think about what I want to do! there is a good satisfaction I suppose when you do it yourself! :cheers:I know there is some pretty good instructions on how to do it on here.. using those magic bar things after the washhave attached an rtf document a made when I copied the instructions off one of the posts long ago biggrin.gifattachicon.gifCar Care.rtf
Nice instructions for car detailing... I'm off to Supercheap Auto :)
Timing belt replaced, fuel filter replaced, airflow meters cleaned, finally found an r33 Gtr aircon compressor but found that the 260rs lines are bigger than the r33 compressor, so now need to find r33 Gtr lines, also purchased a twin 2/1/2 in exhaust off an r33 that I'll get modded to fit, also found the suspension I purchased of eBay was s tune so just sorting out ordering new replacement front shocks, not bad for $65
Edited by poohkies
busy day!
I replaced the factory radiator because it had sprung a leak while towing to Bulldelah with a cooling pro one from Just Jap. Actually I'm pretty surprised the original lasted over 300,000klm including about 120,000klm with the 3l.
  • Like 1
Painted my grill satin black today.. got it painted okay but underestimated how much (or little) paint I had left so the inside bits arent so proper but i cant get more paint bah good friday. Looks okay at the moment.
Edit.. also polished up the fog light/indicator lens' as the were cloudy
Edited by c34Florry
Finished off doing a blue dash light conversion today after a few weeks with out a speedo due to dirt and no globes. Also had my car finally back on the road a month or so ago after a second hand motor went in after a yr of being off the road. And also de badged the grill today as well of the stag emblem and the rs four badge
and painted black like this?
Hi guys just sharing our Stagea 260rs After 2 years out of action due to turbo Failure.
Been racepace done their stage 1 engine rebuild with 2860-9 turbo. also did the LED front indicator and Ganador mirror too :)
POWER!!!
  • Like 1
POWER!!!
That's looks fanastic, love it :) what sort of grill is that? also any more info on the LED's conversion?
It's the Dolphin LED :) mine is the smoked version but you can get the clear LED version. Got it from Yahoo Japan through import monster.
As 66yostagea said the grill is the N/A Grille.
Finally got all the parts needed and had my e-Manage Ultimate installed and tuned last weekend.. Many thanks to Scott & Cihan :worship:
Well worth it IMHO and very happy with the power gains and the attitude of the car. Has made a big difference.. notably in responsiveness and mid range torque. Mods already done include full 3" turbo back exhaust with scotty dump, Turbosmart BOV, Turbotech Boost Controller, Blitz filter, v35 'power duct'. Still running stock turbo, intercooler, injectors, wastegate actuator, fuelpump (soon to be replaced by Walbro). Car made ~180awkw @18psi :thumbsup::D Probably next on the list will be intercooler (and maybe a high flow :w00t:)
Edited by skyguy3804
  • Like 4
Hey Guys
Just thought I'd share what I've done to my M35 since buying it in December, it's an 02 Axis.
Tein wagon adjustable coilovers
Dronell 20x9.5 2 piece wheels
Freeway dolphin 80mm cat back exhaust
Brake upgrade to go on next week!
  • Like 2
Hey Guys
Exhaust looks awesome! how does it sound?
Also surprising how damn good those wheels look on it. keep up the good work
  • Like 1
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
