So after 1 week of android ownership after ipad for 4-5 years..
I cannot believe I did not move over sooner.
the avalibity of apps and tools makes the locked down iOS system seem so clunky.
plus expandable memory is a god send.
battery life however is significantly reduced. however most planes have at least USB power now days so not as big an issue as it used to be.
anyhow 1 more android convert here,.
disclaimer coming from
ipad 1, ipad 2 and ipad mini retina to samsung Note 2014 edition.
  • Like 1
plus expandable memory is a rajab send.
Ahh I went the other way lol
Apple to android back to apple! May have just been bad luck but mine was crap
I found that android software development was ahead of the hardware. The more flexibility & options, the more you lag it down.
Owned the first galaxy tab 10.1 before iphone & found Apple a lot more smoother & simple.
Although haven't played with new gen android phones/tablets so that issue may have been resolved now...
Android still has a long way to go in terms of usability and polish on the overall operating system. It's also reflected in the quality of apps, which are generally awful compared to their iOS counterparts.
Working in IT, being around IT people, I am yet to see 1 IT person go from Mac to Android and then go back to Mac, ever.
An I.T person would be well educated on this and never go Mac/Apple in the first place.
Edited by brat81
I guess you just look for shit unpolished apps then.
Most apps you pay for on AppStore are free on Play
The whole app argument doesn't stick anymore, it did when android was new to the market but now it's just a null-point argument.
The only thing Apple has over android in terms of apps is Siri, Google Now isn't even comparable to Siri at any level it's just terrible, but then again Google is making it themselves from the ground up unlike apple who just brought it then slapped their logo on it and called it revolutionary.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
