Don't know if I could do a lan though it's 2015 man! interwebs!
There's still something very entertaining about all being in the same room, talking shit and having fun...
Most of the time we're playing on a public TF2 server anyway, and deliberately trolling people as a group :P
The new girl at work showed up today in her new car (after having her old car t-boned / written off on the way to her first day here about a month ago). Yesterday she was talking up her great deal / 12 month warranty / etc...
Nek Minit... 2001 Astra, haha... Yeah good luck with that
lol wtf? why would you talk up a car when everyone at the workplace is eventually going to see it
TF2 and Dota 2 is fun times, don't want to sound like a typical wastelander, but I'm the best.
Because she legitimately thinks its a good car... probably because it's got shiny paint... aka, the used car dealer detailed it and peeling paint will show up again after 2 weeks :P
Dota I'm crap at... TF2 I'll give you a run for your money...
She any good?
Yes
Lol I'm actually at my cousins work shop servicing my gfs 2001 astra.
For the first time in car history, chucked obd2 tool on it and no error codes
Also, none of this gay mainstream LAN games stuff.
My share of the list.
Do crashes necessitate a write off or can be a minor incident?
Thefts:
Ric
Borci
Birds
Tony
Alvin
Huy
Crashes:
Hamish's m8
better question, who the f**k faxes anything these days?
I havn;t faxed something since this guy was probably born
Was asked to write something to fax to another place today.... emailed instead. Maybe that's why she didn't reply.
If we play cs I'll probs rage quit after 2 rounds
Also have party games that don't need LAN. Only 1 pc and all players need smart phone or tablet. Pictionary using touch screens is entertaining . Especially with cock n balls
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
