If you have some spare springs available I would chuck something like 7 or 8kg/mm on the front.  If you have some anti roll bars I would do that too although 27mm front sounds odd.  Is it a Whiteline bar or a Cusco?  From memory they are smaller. 22mm?  Anyway the idea is to add more roll stiffness to the rear relative to the front.
Whatever parts you may have try them out to get a feel for setup direction.
At the moment your 16kg spring is trying to resist about 3/4 of the roll which loads the tyre up hard relative to the back.  Then you are asking it to turn aswell.  So you get understeer.
  • Like 1
it was a 27mm front... was a whiteline but custom made... it was the setup I used on my drift car and changed everything when went to MCA reds and therefore std sways
Ive sold those bars now... pretty sure 24mm front 22mm rear is the standard whiteline / r32 setup for circuit
I still have a full set of the teins sitting in a box at 7 and 4  but also have the spare MCA springs
I agree with you on the roll control and turning..  that was my thoughts also ...
updates on recent happenings
I wont post a pic of the new diff and tailshaft because well it looks like a diff and tailshaft :6_smile:     but   preload taken out of diff, breather tapped and line run through the floor into a mounted canister / breather. Tailshaft is a 1 piece - saved 4kg there also
With that done and the car back at home came the time to sack up and get working on the splitter - can only give these things a go and its cheap enough and just some hours in the garage to get it done
Basics for those DIYers at home
Specs = 1900 wide, total length is 1200, rake from front to back is circa 2 - 3 deg (roughly)
               The splitter itself weighs 6kg ... total weight with frame nuts bolts paint everything is 10.1kg without cutting any bolts to length yet
We actually took just over 1kg of tags etc etc of metal out while we where under there  and saving on tailshaft so far above happens net a 5kg+ gain in weight - albeit at the front
We extended some tube ally out the back of the splitter to some sleeves welded tot he chassis rail behind it for stability and ease of install, once slid in there is 6 x 12mm oem bolts to bolt up which is made from tags with oem nuts welded to the back
the ally frame is welded and then bolted to the splitter using m8's and also sikaflexed down
Tested it with 50kg in middle 3rd and 30kg on each other third adding weigh bit by bit. Strong no flex at total weight of 110kg with front end coming down 25mm with that weight on spring compression. Didn't go any heavier just wanted to see if it was going rip of easily or not haha
all back yard read > making > hoping > trying - but that's half the fun sometimes
the front lip of the carbon airdam is / will be held down using 7 x M6 bolts with nylocs
painted for looks
The current height is 850 front the ground , will be lower the car by 5 mm to get it down to 800 which will be enough, not optimal but don't want to compromise suspension geometry
And pic just because
Out in two odd weeks to try and go round and round a track fast
Just basics to do now like wheel alignment and fluids change / check
Sway bars are on order but wont be here in time try this..... add sways try that... see if successful in either pursuit and see if I can get some consistent track time over the next 3 months
  • Like 5
Its probably the way the photos are taken Id say its wide but not that wide
the carbon lip that comes down directly off the GTR bar is 178cm wide, outside tyre to outside tyre across the front is 182cm and the width of the splittler is 190cm - so its only 6cm a side wider that a normal GTR width and 4cm and side wider than the tyres so when you look at that its not bad at all really
And I just do sprints so basically no wheel to wheel action :1310_thumbsup_tone1:
Quick update:
Went out last wed night. Really good night heaps of track time which was great sat a few session out because well Im old and me and the car gets worn out :1_grinning:
Long story short the two handling changes being the splitter and the diff has made the world of difference. Id say mostly the diff but all contributes as you know. I have a car that turns now !!!!   so good
With invention of actually turning around corners not just the rear end pushing the front through it means I have to accept that I cant just mash the throttle on exit on go so little later on the throttle now with a decent hint of oversteer if  you get it in the wrong  spot, my drifting skills are a bit rusty but got tested a few times trying to find the new limits.
With the wing on 0 deg angle, the rear grip alignment was set at neutral and the rear dampners on hard there is much room for more rear grip to be added
I spent most of the night trying to find the new balance as it really was quite different but feel like im actually driving the car now and have taken the handling problems from really big to a now manageable amount through tuning with what I have and am getting.
New PB was set just on 5 event old tyres and we did a top 10 shootout at the end of the night (one lap dash) an I was within 0.8 sec of PB on cold tyres etc
All in all moving forward and much happier.... for now :8_laughing:
Edited by bcozican
  • Like 2
  • 3 weeks later...
Build bits and results
Few little additions recently. Trying to run the ride height I wanted to ie: lower was leading to suspension geometry issues. I bought some gkteck knuckles that had 20mm drop built in to attempt to correct that. After what I admit was a fair bit of messing around with the usual change one thing and effect 5 other things we got these in with new bearings, wheel studs etc etc. It served its purpose for both correcting steering geometry and also letting me run the ride height I wanted but correctly.
The new tailshaft over the last event and a test and tune was rattling my teeth out with vibration so gave it back to Final Drive who rebalanced it and put that back in and all is good now
Off to Allstar to final give the power a bit of touch up... been running 490hp and 550nm @19 psi successfully Sean gave it another tune I can run off a switch adding 4psi so now 550hp and 660nm full boost at 4100. That's a fair bit of pick up from 4psi.
Everything on the car to remain 'balanced' without it being too pushed or unsafe ie: brakes is made for 500 - 550 hp - try for anymore and I really run out of turbo, injectors, clutch, brakes
The car was also due for some new tyres - I had some fronts I bought cheap from over east new but 3 years old and some new ones for the rear
I also picked up the Vbox for future events so will get that in soon.
Last night ran at the Trackbattle night I like these night cruisey but decently professional good amount of track time and good people. After a bit of rain gave this thing a crack and got a new PB by a decent amount knocking 0.9sec off my existing PB ....lap time doing 2 x 62.1s and I think about 7 - 8 laps in the 62's
Edited by bcozican
  • Like 4
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
