12 minutes ago, IMACUL8 said:
Thanks Ben
As far as a Quaife sequential - that's what I had previously - never again.
Is that because of parts support from SVS or because the box wasn't up to it ? You had a QBE33G, the 750hp rated one from memory right ? The current QBE91G sequential is a completely different beast (released in 2017) and I am yet to hear of a failure - has much higher torque load rating and seems like they actually have it right this time.
I used to deal with then a lot with the Trust / Quaife H dog box and found their parts support pretty decent.
Anyway best outcome is really to sort your Albins issues out directly with them.
  • Thanks 1
Man that sucks.  you've got all the nice fruit and to be held up bolting it all together because of a few little componenets  must be bloody annoying!
Sell the gearbox and buy a pool for the kids?
  • Like 1
lol - already got the pool mate ;)
Its D day.......   consumed with this..... Pass the albins off now - and slide over to Samsonas.... or stay with Albins.....
Thanks for the recommendation Brett.......  for me the big thing is how easy Jason is to deal with - and how quick he responds / communicates with me....  that gives me confidence in the event of any issues.......
  • Like 1
My 2c, stick with the Albins, stay on top of your supplier and roast them for the delay, but wait it out. I know a few boys now running the Albins and all are very happy with them. Think of it like this, it would be a GTR if it didn’t give you stress!
  • 1 year later...
Update.
Stage 2: (Aug 20 – Feb 22)
Borg Warner EFR 8474
Albins ST6 Gearbox - 6 Speed / Street Ratios
Platinum Racing Products - Billet Sequential Shifter Unit
OS Giken 4RC Clutch
Haltech Elite 2500 PnP ECU
Flex Fuel
Recaro Sportster CS Seats x 2
Bride Super Seat rails XR Type x 2
Work Meister SP1 S3 18x10.5 +12
Catch Can Modification – add filters / coat
Custom 3.5” Stainless Down Pipe
Custom Gearbox Oil Cooler (Rear mounted)
Custom Power Steering Reservoir/Bracket
Silicon Intercooler Joiners - Black
Aeroflo Fuel Rail
2000CC Bosch Injectors
Custom R34 GTR Steering Wheel – Carbon Fibre / Alcantara
Samco Black Radiator Hose kit
  • Like 8
Yes - The current shifter PRP are selling for the Albins boxes - "Billet Sequential Shifter Unit" - is what I had to wait for.
The package was sold to me as a bolt in option - no mods to tunnel required / no mod to tail shaft etc.
The box itself fits amazing - mechanic said fitment was spot on - just like factory.  Uses stock shafts and standard cross member to - no need to purchase different cross member. But the shifter initially supplied did not work with standard tunnel - it would need to be modded - which I was not willing to do.  So that's where the drama started. Back and forth for 9 months / 3 or 4 versions - and finally we have a shifter that fits without tunnel mod.
Special smaller / bent fittings are also needed to make the gearbox oil lines fit with no issue/no mods to tunnel.
The actual box - is fantastic.  Extremely happy.  Ill post a vid of the sound !
Edited by IMACUL8
  • Like 1
I really like the shifter as it doesn't have the bulky base like the Samsonas.  I am having the factory gear boot re-done in Alcantara with the opening just slightly larger to accommodate the shifter.  Once fitted - will look stockish at the base with just the shifter giving away any clues of shenanigans!
Edited by IMACUL8
  • Like 6
I will post some better pics soon - I have car for run in and it will be going back for a finish up / check soon (including new coils).  I'm still waiting on a few finishing cosmetic items.
I must say a big thank you to Benny who is a big advocate for the EFR turbo - the 8474 with the 2.7L is a response monster.
Power everywhere - every gear - instant power.  Its amazing.  Car will be re-dynod when it goes back with new coils and I will post results after that.  As a comparison to my T76 (502kw at wheels) - this kills it.it would be making more than 500kw with response and power everywhere.  Extremely happy.  They not as pretty as the Precision - but fark me they are amazing!
Edited by IMACUL8
  • Like 5
On 01/04/2022 at 5:18 PM, IMACUL8 said:
Update.
Awesome build, and the 8474 is an excellent turbo - a made recently made 620kw @ hubs on his 2JZ with an insane power curve.  If you aren't shy with it then you're going to completely slap the old T76 setup everywhere :)
Always concerns me seeing Bosch 2000s, especially on builds like this.  Hope you don't have any issues - look forward to the final results!
Also are you still running the factory CAS or has that been modified to just only return a home signal?
If that's OEM I would swap it out for a NZ Wiring cam trigger kit, 24 -1 setup but you won't have triggering errors like the OEM optical wheel
Also brakes wise, look at 355mm 370Z calipers using Z1 Motorsport adaptors. Should be plenty for your car and track work when paired with decent pads.
Yes I believe I am.  CAS and coils will be done when I return the car shortly.  Not sure yet as to what option I will use for each as yet.  Very keen to get it done and push the tune more.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
