19 minutes ago, Full-Race Geoff said:
Built b series drag race Honda, full race top mount kit.  only turbo changed- no other changes.
Green line = 9180 1.05 a/r
Red & blue = 8474 1.45 a/r
This is from the blue DC2, right?  I was told that this is running an EFR9280 now, and that this comparison is comparing the EFR9180 with the EFR9280.... in fact, if there are no crossed wires then there is a pic of this car on the Full-Race FB page saying it has an EFR9280 now
Edited by Lithium
I am also looking for a T4 1.05 External gate twin scroll housing for EFR7670 if anybody knows of one for sale.
Part number is 12701019047
I am unsure if all B2 turbos use the same 'D type' rear housing that i am looking for or if it is specific to only 7670
Thanks
Thanks
It would be turbo specific to fit the right sized turbine wheel.
2 hours ago, Nosure said:
Any idea is that direct swap from 8474 1.45a/r to 9280 1.05 a/r without any exhaust work?
Between the 1.05 and 1.45 housings is 7 mm. The dump has to move back 7 mm, it doesn’t matter if it’s a 80 mm wheel or 74 mm wheel.
Ok. . Thanks. So 74mm 1.45 to 80mm 1.45 they should be direct swap.
This is a great thread,
After reading a huge chunk, I have a question for all those high hp setups running 8373 and up.
What exhaust are you all running on these Skylines?
Reason I ask is because I ran into flow issues on my little track built EVO X running 8374 (IWG) with a 3.5" straight through race exhaust, we removed it and ran with downpipe only and made 30whp gain at only 1.6bar boost. I can only imagine how much more power you can make with a side plant (exhaust cutout operated with a valve). I'm installing one now...
I was looking to upgrade my 8374 to a 9180 but now thinking after reading this I'll go to a 8474, my setup is sleeved block 2.2ltr (4 cyl obviously) with direct port meth injection, sequential 6 speed, head work, oversized valves and makes over 600awhp on a mainline dyno (I flew the boys from Powertune over to tune it). peak power is 8500rpm and I get 2 bar of boost by 3,900rpm in 4th gear. Car weighs 1280kg after stripping it (with roll cage) and being built for Sepang F1 circuit.
Edited by Robo
  • Like 3
'little' evo.
You can plumb an exhaust in if you actually plumb it further back (and not lose power), but realistically when you've gone to the degree most people have in these kind of builds it's venting to atmosphere and everyone prefers it that way.
Hi Robo,  thanks for using our EvoX turbo kit.  2 bar at 3900rpm is excellent for the 8374.  What exactly are you looking to acheive and do you have any reason why you would not want to go external WG?
In the case of a RHD evoX, there is less room than LHD.  As you know, the steering shaft area is your space constraint from using a large diameter downpipe.  Dumptubes for an external WG can be tough to package - but doable.. depending on what your exact goals may be will ultimately dictate the piping configuration.  you are welcome to email me directly to [email protected] and ill do my best to help
Edited by Full-Race Geoff
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
