1 hour ago, BakemonoRicer said:
Are you aware the CD009 will become the lowest point on the car? They hang a LOT lower than the chassis rails, just an FYI.
What you need is a Samsonas.......
lol... fuark the peer pressure is real, also my car isn't that low (as you can see in the photos).
38 minutes ago, BakemonoRicer said:
Paintjob looks mad.... did you take the strut towers off to do a rust repair while engine out?
E.g.
http://blog.garage-yoshida.net/wp-content/uploads/2021/02/IMG_0100.jpg
http://blog.garage-yoshida.net/wp-content/uploads/2021/02/IMG_0099.jpg
We sanded the towered back to bare metal around the rust areas, wasn't as bad as those photos. Hit is mum with rust converter and re-sealed, then painted over.
For real, I am currently shopping for a very expensive gearbox while my clutch is out. (???? cars...)
Buy once, cry once, then enjoy the benefit.
That said is there actually any benefit with a Samsonas for your intended use 😛
Can grab another gear mid drift at Powercruise and look like a sik karnt :D
But no.. I will not Samsonas my car.
  • Like 1
But how can this should work at all ? . . . . .
Easy samosa recipes to cook at home during lockdown
2 hours ago, dr phil said:
Somebody please do a BMW DCT conversion. There is a GTR kit now for the transfer case too.
I looked into this for the LS! It looks like there's an adaptor plate for the LS, and the gearbox itself....
... and nothing else. No easy to find dimensions/sizes of things, no electronics,
Noone sells the rest of the 'kit' to make it actually 'work'.
But I wish they did >.>
I'm looking at this for the Silvia using HGTs stand alone. It "appears" on paper to not be that much more than CD009 conversion, but obviously with a little more work/complexity.
As my car will only be a little 4cyl, I am hoping I can get away with the ZF8HP70 or 75.
Flappy paddle last minute corner entry/exit changes would be pretty hektik though...
  • Like 1
Very sex, this is why you see M2/3/4s at Wakefield just fly out of the fish hook, all the manual boys trying to rev match, shift dis dat, they're just cycling through the gears and flying out.
  • Like 1
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
    • Sequential Is fine to drive on the street
