2 hours ago, TXSquirrel said:
Full digital dash for 32?  Why didn't I know such thing exists?  Who makes it?
It’s a motec ac1212 12’ display. To get that look you have to also purchase software which gives full flexibility to create or mimic any dash you like, then you can add / customise to your liking. I’ve already got ideas of what I want to create. Will post up when it’s done. But it ain’t cheap
Ahh I see. Yeah at that price point it's going to be at the very bottom of my wish list. Does it only work with Motec ECU or it can be wired to Nissan consult?
The motec dash’s can work with just about any ecu, but Talk to your tuner/mechanic to make sure it will work with what you got. My car is being built by Powertune, they are a Motec dealer so you can contact them for pricing and to confirm if it will work with your ecu
Well, stereo is almost done, got the new alpine double din head unit and amp installed, took some time but turned out ok, just need to fill a small gap between the head unit and climate control, it all fit in with no cutting or drilling any holes so I’m happy about that, and it sounds INSANE! For such a compact unit, it sure packs a punch, getting everything out of the speakers. I’m running Focal splits up front but a cheap set of Clarion 6x9’s rear. I’ve bought a set of Hertz Mile’ Pro 6x9 which I’ll have a go at fitting tomorrow and see what difference it makes.
but bottom line, I wanted a set up that would give a good range of sound without the aid of a sub and it has delivered. I’m very happy with the result.
next up, Motec dash ?
  • Like 3
Yes, I asked the boys at powertune if it could be done through the motec, unfortunately it can’t, the dash has an input but no output, I’ve gone double din as I did not want analog gauges next to a digital dash, I’ll be keeping the old set up and I’ve still got the original triple gauge cluster.
I’ve got a design in my head of what I want from the motec dash, just hope it can be done, will be talking to the boys on Wednesday when I drop the car off. If what I want can be done, I’ll be very happy
Stereo is finally finished, speakers were a nightmare. The Hertz didn’t fit, ended up getting a pair of Kenwood, I’m very happy with the sound quality. Also I tidied up the install of the head unit and filled some small gaps. Overall i think it looks good and nothing was cut.
now time to just relax and enjoy the rest of my Sunday
  • Like 3
Why would you need to externally display anything on the head unit when the dash can display anything and everything? I think the thing to remember with CAN dashes is you don't need to have eyes on every engine parameter. You can have a simple display showing the things you need to know, a la stock dash, and then utilize maths channels and warning functions to pop up messages when a change happens that you need to know about.
Also, I'm quite sure the Motec display creator will allow you to have literally anything you can imagine. I helped set one of these C1212's up for a customer who wanted a naked cheerleader in the middle of the speedo and tacho, and her arms were the needles. So as revs and speed went up, her arms moved and she showed more... skin. It was a laugh for sure haha.
Haha, sounds like something I would like.
in regards to displaying on the stereo screen. I was curious if I could set something up to have 3 digital displays on the screen, as a ‘throwback’ to the factory layout of the interior, it wasn’t a deal breaker (obviously) and it doesn’t really bother me, I’ve got plans with the dash layout to be a modern improved version of the factory layout.
  • Like 1
Don’t you just love when this happens!
It was my fault, I shouldn’t carry cash in my wallet, the car can smell it!
looks like the lift pump died, at least it was on the way to the mechanic ?
shout out to Mick from Micks Towing, you’re a lifesaver, top bloke, great service and fair price.
  • Like 2
  • Sad 2
One of us! One of Us! ?
Legit, GTRs spend half their life being transported to mechanics...
Poor timing though. If only it had made it 99% of the way. You could have parked it, dropped the keys off then casually mentioned, by the way it doesn't run now.
Hopefully it's just a replacement for you. Better to happen now than while you're out blasting around in the hills.
No Steve, it’s such a bitch, when I got to the mechanics, it f**ken started! But the surge tank was empty so he thinks the lift pump might be on its was out. He will check the logging today to see what happened
  • 1 month later...
Well might be time for an update, I’ve been in a bit of a shopping spree, bought a set of factory seats, factory Jap spec seat belts, genuine diff housing, numerous genuine nuts, bolts, clips, etc. Got new rear quarter upper trims as well as a few other bits and pieces for the interior.
I’ve got almost all the parts I need to start the new rear end set up. Bought a new Whiteline sway bar kit. Whiteline subframe bushes and the GK Tech hicas elimination kit and subframe brace kit. Got a GTR diff housing yoke and new ring and pinion gear. Got my hands on a second hand set of 31 spline stub axles and will be using a quaife centre.
Car is still at the shop, has had quite a bit done, brakes are done, now fitted with brembos front and rear, callipers overhauled with new seals etc. Blasted and re coated. N1 brake line kit fitted and abs deleted. Coil overs were removed and sent away to be serviced, new seals etc. Hard pipes are done and coated (no more silicone joiners)  front cover of the turbo has been hydro dipped. I’ve ordered a new front lip from concept garage, should pick that up tomorrow.
If you’ve read the thread, the car was towed to the shop, initially thought a fuel pump failure, have since discovered its wiring. Basically, it’s a bit of a mess so we’ll be ripping it all out and fitting a pdm. I’m also discussing option with the fuel system set up. Looking at moving the battery to the boot and fitting a surge tank where the battery normally sits. Will be exactly like this setup. This will get rid of the surge tank in the boot and the lines from the rear of the car.
there is probably stuff I’ve missed, it’s been a little full on with it and I’ve got GTR parts all over my house!  Lol
  • Like 5
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
