Well, after almost 3 months, tomorrow is the day, when the GTR comes home...for a bit. An extensive amount of work has been completed, marking another step in the cars evolution. Still a long way to go before it’s finished, but I’m happy that a lot of the ‘little things’ are now sorted.
The car went on the dyno to sort out a boost creep/spike issue, it had a blend of 98 and e85 and was at about 15% ethanol content. It made 420 awkw on the rollers @20psi (gate pressure) and that’s wearing Toyo R888 tyres.
looking forward to getting it back and taking it for a run.
  • Like 5
3 minutes ago, PranK said:
Fantastic! And she looks great too!
Hey, any chance of a video of the dash working? A few keen beans on insta have asked.
No problem, I’ll get one up on the weekend
  • Like 1
Yes, it’s really nice. Was good to drive the car again, forgot how bloody fast this thing is. Even on gate pressure running 98 the thing is an animal on the street. But you can feel the reduced power in the top end, but it’s really strong through the mid range.
I found out the motec uses the wheel speed and rpm. The gear ratios have been entered in so it can determine what gear it’s in. Actually works really well.
  • 7 months later...
Well this never ending build is finally moving forward. Car is going to the shop after GTR festival to have the motor removed, then it’s off to get the bay painted, then the new 2.7 stroker motor is going in. I’m also replacing the cooler to a Plazmaman 100mm comp spec and the entire hot side. Going a 6boost manifold with egt bungs for each cylinder and new turbo will be a Precession 6875.
And while I’m there Pro wire will be making me a new custom engine loom and cleaning up all the other wiring in the bay.
after this I’d like to think the bay is finished? If there is such a work in the GTR world 🤔
  • Like 1
6 hours ago, MoMnDadGTR said:
nice unit mate, hell of a read. that dash is wicked too
Cheers, it’s been a long road, with many ups and downs. Hopefully at some point I’ll get it to where I want it.
Ahh don’t get to caught up in the details mate. Don’t get me wrong you have done a job I couldn’t never do my engine is a hack compared to that lol. But it’s good to be content and enjoy what you have! Your car is wicked mate go bag the piss out of it. Cheers.
  • 3 weeks later...
Well, I’m going back to a 2.6 based motor, just in the process of getting everything together, things getting re-furbished, coated or replaced with new where I can. Car is at the painters now, decided to paint the bay the colour of the car. Also sold my hotside so it’s being replaced with a 6 boost manifold and 68/75 turbo. I’ll also be running egt’s and getting a new engine harness . But one thing at a time 🤔
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
