G30 turbine flow :
Les turbo garrett G series - Page 4 G30turbineflowmap
G35 turbine flow :
Les turbo garrett G series - Page 4 G35turbineflowmap
The compressor flow chart :
770 :
Les turbo garrett G series - Page 4 G30-770comp-map
The 900 one :
Les turbo garrett G series - Page 4 G35-900comp-map
and finally the 1050 one :
Les turbo garrett G series - Page 4 G35-1050comp-map
All were taken from ATP website so I consider these as legit but still take these with a grain of salt as they were not officially released.
Understood, and very much appreciated - thanks for sharing - that's awesome.
I'm pretty confident they are legit, btw.  Just probably weren't meant to be released yet
I've had a quick play with that data, and if I am looking at it right - the 1.01a/r G30 hotside is very comparable to the 1.05a/r EFR8374 hotside which puts things into perspective.
The .83a/r G30 hotside falls slightly short of the .82a/r GT35 hotside in flow.   I think Garrett have chosen some very nice spread of options with this range.
  • 4 weeks later...
On 12/04/2019 at 4:41 PM, Phat_Toni said:
The g25 660 with the 0.92 looks comparable to the GT3076r but seems to have the edge in turbine flow, compressor flow and spool.
g25 660 0.92 from ATS
6boost mani
I saw a post on Sinco NZ's Instagram page which made me think of you, how is your build going?  Did you end up going Sinco for the manifold or is there someone else doing similar?
1 hour ago, Skylineusa said:
This page is gold with great information. Thank you guys! Would running twin 550 be a worthwhile combo?
That's a very open ended question.  For what power target and on what kind of setup??  Do you have the budget and inclination to do all the fabrication to do twin 550s? (it's not something you'd do on stock manifolds/location).
It is the kind of setup which to justify would need a pretty solid engine spec, basically its a 1000hp turbo setup so expect the kind of lag that would come with one and expect to need to do the kind of engine and transmission development needed to support it.   If you are looking at making the typical kind of power that people go for with low mount twins then no, imho it is not worth doing.
5 minutes ago, Phat_Toni said:
I think this car was mentioned earlier in the thread. Gives a good idea as what to expect from 2 of these things....
It's worth nothing a couple of things he says which contradict each other, he implies it spools 500rpm better than the EFR9180 but then also says its all in between 6000-7000rpm which on a 2.8 is... umm... much laggier than any EFR9180 I've heard of.
It's been previously said that it's got a 500rpm wider powerband as the 660s hold on (unsurprisingly) to much higher rpm than the EFR9180 and other turbo setups they ran on it, so if you are willing to rev it to 9000+rpm then it offers the potential to give a broad delivery - as long as you aren't hoping for things to happen earlier in the rev range.
Be great to get some more data points from that car.
The twin G25-550 intrigues me as well.  They do the internal gate T2 .49 which screams bolt me on an RB26.
I've be told by a seller its not a bolt on affair though. I was not given any details other than you have a 30 year old car "dude" as to why.
The cost of them makes it a serious investment and a risk you end up with a street pig.
If not and they make 900-1000fwhp with amazing spool  ..... all the glory is yours  ......
When they released the spec sheet on the g25 I looked at them real hard. The problem I saw is they are longer than the stock turbo. There just doesn't seem to be horizontal room for them. Granted this is based off the spec sheet and not trial and error.
If we could slant them 20° from horizontal they might fit but you can't do that and expect the snail to live.
Sorry Lithium, you are correct. I should have gone into a little more detail. I was thinking for quick spool, which I understand by your reply, and looking at the map, would not be a good marriage. It looks like I will wait for the 770s to come out, and go that route.
Hypertune makes twin manifolds for the G25s, if anyone is going that route. My car is more street than track, so I really do not need that much power.
Edited by Skylineusa
I hope you mean a single 770? :o
  • Haha 1
Yeh its interesting.
I am in the process of getting rid of my HKS F-con rubbish in favour of a Link g4+ and upgrading my trigger system and fuel system at the same time.
Once done the G30-770 be on the next list to replace the -5's.
So sooner they come out the better so someone else test for me.
  • Like 3
    • Nah, they'll do it without a receipt, tell em roughly when it was, that it was cash, youll likely only get store credit, but that gets you some dollars towards the newer better shovel, or other item you need/want later.   Still take it back and have a crack at returning it.
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
