2 minutes ago, Phat_Toni said:
Very interested to see how the G30 based turbos compare to the GT30 based turbos in terms of response. Im expecting response somewhere between GT30 and GT35 in comparable housing sizes...time will tell
A mate is going to be trying a Gen2 GTX3076R with 1.01a/r hotside and a G-series turbo for comparisons sake, not 100% sure which but it seems like it could end up being a G30-770 with .83a/r hotside (most similar flow rating to the 1.01 GT30) on a built SR20VE.   That should be a relatively interesting comparison.
Edited by Lithium
  • Like 5
I'd like to hear those results...
On 18/07/2019 at 12:11 PM, Lithium said:
I saw a post on Sinco NZ's Instagram page which made me think of you, how is your build going?  Did you end up going Sinco for the manifold or is there someone else doing similar?
Progress pic...Snapchat-1139584873.thumb.jpg.a226fa3f2b7d36ee8c75b5e3d340a30f.jpg
  • Like 4
G30 660 and 770 at jamboree last weekend. Asked about t3 or t4 housings possibly in the future but only doing vband housings for now. They are a direct bolt on replacement for g25 series too.
Edited by robbo_rb180
More info
  • Like 2
I was just looking at the dimensional drawings at the ATP site , it appears that Garrett have used three slightly different compressor housings .
The G25-550/660 and G30-660 use a 0.70 AR housing , the G30-770/900 and G35-900 a 0.72 housing , and the G35-1050 a 0.75 housing . From memory their diameter's are around 170 190 and 205mm .
A
  • Like 1
So, are they going to be doing the T4? Or did they not answer the question? I sure hope so.
They said no at the moment. Maybe in the future. Would have liked to try one in t3. 92 on a Rb25
I have a G30-900 0.83 on order with an 8-10wk wait,currently 2wks in, the anticipationis killing me, but just to top it off I had purchased a GTX3584RS the day before they were released ??? so I returned it for the G30-900 instead. I don't mind dropping up to 100HP for farrr better spool. I anticipate 700awhp out of my 2.4L built MPS. The big cams and the oversized pistons should get it spooling early, tbh my biggest worry is that it might choke it up top
Edited by Yaji
  • Like 1
  • 1 month later...
hey fellas, just had a read thru. thought id chip in.
ive been running the .92 g25-660 for about a year now. semi closed forged ej25. amazing turbo, spool, mid range everything. almost as responsive as the tiny factory td04.
in my humble opinion, this is too small for an rb. you'll get mad response, but no top end.
runs about 340awkw at 26 psi. under very strict controls, pulled timing, torque limit etc.
clutch and semi closed engine holding us back. still makes 100kw at 95kph, and 200 kw at 110kph.
have since exploded that clutch, now have a new twin plate on there and a more efficient cooler. if i get it back on the dyno any time soon, ill drop back round to post the sheet.
we also, have a sleeved ej28 stroker in the build hopefully to have a g30-770 or g30-900 attached to it. with the current wait times, and gcg having the monopoly (and also charging full price upfront to non traders) it could be a while. once MTQ has stock, we will be all over it.
  • Like 3
  • Thanks 1
that is great feedback!  I absolutely love the G25 with 0.72.  The 0.92 flows a ton (very impressive actually) but did have some response loss.  I would love to see any boost logs you can share.
and if you wanted to try G30-770 we have them in stock at full race
here are the dyno results. incredible spool, amazing torque and a very long power band (for a subaru)
28psi by 3800 rpm. thats plenty of response! unfortunately the stock heads are killing me with its tiny cams and weak springs. would like to see this with 272s springs, and a 4 inch exhaust.
i raced it at the weekend in the local sprints. such an amazing car to drive. cannot talk highly enough about this turbo!
edit the previous run of 340kw was done at a higher ramp rate. it was dropped to 10 for this.
on the shoot out mode that some "tuners" like to print out, should made 370kw at all four. gotta love dynos :)
  • Like 3
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
