Apologies, I know there are probably loads of threads about this. A search brings up a stack of results but nothing that specifically answering my question.
My stock turbo popped on my R33 GTST (I think its series 1.5). There is slight shaft play and the impeller is touching the housing.
Question is, should I recon it and have the ceramic wheel replaced with a metal one or change the turbo?
My end goal is 400-450hp. The plan was to do injectors, MAF etc. before the turbo but i have to change that around now.
If I change the turbo, what are the suggestions for something which will be a straight swop or close to it?
The car is basically stock with just a milteck exhaust.
https://www.sau.com.au/forums/topic/473250-suggested-turbo-on-a-stock-rb25/
I used he atr45 externally gated from hypergear turbo on my 33 on 98 and made 300kw atw. Great bang for buck. I had all supporting mods 750cc injectors haltech etc if you Have more money to play with gtx3076r gen 1 or 2 is also a great responsive turbo.
Another vote for GTX3071 here.
OP mentioned he was thinking about injectors and AFM etc, so this is a turbo that will make the most out of that. GTX3071 may be not THE_BEST_EVER for outright performance on stock RB25, but it is by far the simplest way to get 99% of the performance anyone is going to ever need given what you've said just now.
I have an Rb25neo with an ATR45 and a mate with a GTX 3071 Gen 2 also on an Rb25neo making roughly around the same power.
Cept my ATR45 is laggy as and you really feel the boost kick in. GTX 3071 Gen 2 is linear and happy days.
High mount, twin scroll, twin gates or one massive single gate and a modern turbo.
Keep the exhaust pressure down and the motor will live.
Food for thought, stock motors will happily crank out ~370kW at the wheels for days if you don't abuse them like a wh0re on the track.
  • Like 2
Atr43g3sat with external gate from hypergear looks to be the goods, best response for that power from what ive read and also for the right price
Surprised by all the gtx3071 votes, lots of people talk about using that turbo but ive not really seen too many that do (dyno graphs that is)
Not sure if there are many results on the GTX 3071 Gen 2 on an RB25 but here is one:
Its a built motor though, but it also has alot of restrictions.
For a internally gated setup the flow of the engine system is strongly dependent on the exhaust, so in a common scenario it will be what ever an 3 inches exhaust can flow, and that is usually up to around 400HP wheels. Anything rated to higher power levels is recommended to work with an external gate unless can run a big straight pipe to ground.
Far as power and response, I recommend our latest Ball bearing ATR43SAT series.  ATR45SAT (Note: ATR45 (3582) and ATR45SAT are very different turbos) is capable of making alot more power if externally gated is in mind.
ATR43G3SAT CBB Power 317rwkws P98 fuel internally gated
ATR43G3SAT CBB Boost 317rwkws P98 fuel internally gated
19 hours ago, Die$eL said:
The car is basically stock.
There's a lot of recommendations made that are going to require a $10k minimum spend to make the car capable of running reliably.  They're not bad ideas, just failing to acknowledge the financials.
Until OP is prepared/able to pony up for all the regular associated upgrades - ECU, cooler, proper exhaust, fuel system, clutch, rubber, brakes, suspension I'd say he's best to stick with a small close to stock sized replacement running low boost eg 10psi and keep motoring until the funds are there.
  • Like 1
Well, if you want to be sensible about it, it doesn't make any sense to buy the "wrong" turbo for his end goal now, just so it won't overrun his injectors and AFM.  Piggie's original recommendation (and mine) implied that he would buy the turbo he wanted AND make sure he had the fuel and management also, although I'll admit that we didn't make that real clear.
Needless to say, the whole exercise is probably best reconsidered.  What the OP really needs is a 2nd hand stock R33 turbo to throw back onto the car until he is actually ready to do the needful.
  • Like 1
But it's SAU, when does anyone listen to sensible recommendations?
My pick would be:
  • Top feed conversion
  • External FPR
  • Wallah bro 460
  • Splitfires
  • Nistune with Feature Pack
  • Continental Flex Sensor
  • EBC of some sort
  • HG G3 Highflow
  • Decent FMIC
  • Decent TBE
  • 1.5/2 way LSD
  • Decent coilovers
  • Traction Rods, Rear camber arms, castor rods, HICAS eliminator
  • Intima SR brake pads all round
Call it a day, 300kW street beast.
My pick would be:
  • External FPR
  • Wallah bro 460
  • Splitfires
  • EBC of some sort
  • HG G3 Highflow
  • Decent FMIC
  • Decent TBE
  • 1.5/2 way LSD
  • Decent coilovers
Pretty much just described my car, almost. Can confirm its an awesome setup on E85.
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
