6 hours ago, Murray_Calavera said:
BCPR7ES. I change them every 20,000 kms.
A search will probably dig up quite a few threads on what spark plugs to use.
Exactly the same, I just run coppers and change them every oil change or 2. Iridiums or factory platinums just won't last long enough to make the much higher up front cost make sense
I had iridiums in my RB and they lasted a decade, through hell and back.
You should routinely check them anyway... hence coppers aren't such a bad plan. They can be pretty easy to change in a RB which is why most people are OK with it.
3 hours ago, admS15 said:
Another for copper. I didn't listen to the sau gods intially many moons ago and bought platinum. Don't think I even got to 20k KMs before they fouled up.
Is that an issue with the car running rich or lean, or just simply because it's modded it requires more frequent maintenance?
Plenty of 600kW~700kW RBs from Birrong Automotive just use NGK Copper plugs.
In today's day & age of E85, you could just slap in Iridium plugs and reduce the number of times you change your plugs.
I personally just use copper plugs, and get them for about $3.50 each when there are discounts on Sparesbox or Supercheap Auto, etc. I run them until the car starts to misfire and then bin them. This usually happens after a few years of use though.
I still have 24 plugs on the shelf, whoever buys my car will get all the plugs, 20L of Penrite 10th Tenths, 5x Z442 oil filters, etc.  LOL
Duncan is a Wolf of SAU
29 minutes ago, Duncan said:
well, the truth is I change the spark plugs every time I rebuild the engine, I can't wait until an oil change is due.
Rookie. My iridiums lasted through engine rebuilds....
  • Haha 3
I used to use coppers, but now use the IRIWAY's  cos yes plugs aren't hard to change on an RB but, still is maint and time, and wear on the aloominum (go USA lol) head threads everytime they're changed. The IRIWAYS have been great, but will foul a little if you putter around too much, so good excuse to give it some full volume regularly and keep them working properly. I replaced the IRIWAYs around 50,000k's? and don't know why I bothered, they still looked fine. Only on my 2nd set now for don't know how many years, but it's alot.
I use Denso Iridium Power. $58 for set of 6. heat range 20 (aka 6) right in the middle. shouldn't foul with my brand new coils. for the price alot easier than pulling plugs out on every few services.
Edited by ACTIVE-LSD
I use Denso IK01-24/NGK R7434-8 as I have R35 coils
RB26 coils use IQ01-24/NGK R7436-8
Sparkplugs/Coilpacks - 600kw - Forced Induction Performance - SAU Community
they are platinum iridium and make an excellent spark and last a long time as the ground strap is pure platinum
can be had for reasonable money from rhdjapan. they're VERY expensive in australia.
Edited by burn4005
  • Like 2
  • 4 weeks later...
Only plug to use on a 500kw onwards RB mainly because of the Platinum ground electrode, as all other plugs can grenade the nickel ground electrode right off with any detonation quite easily.
  • Like 1
  • 1 year later...
I've been running R7436's with R35 coil packs on my RB28. I was wondering what made you jump over to R7434's with the R35's coil packs?
Thanks,
  • Like 1
Thanks,
The R7434 and R7436 are the same plug except the 36 is a 2.5mm longer overall plug as the insulator 2.5mm longer. The 34 is the BKR length and the 36 is BCPR length, which RB26s use as standard.
I'm still on the 36 because stock is BCPR. I will change to the 34 next time as the 36 tends to jam in hard to the coilpack stalk when used with the full height RB R35 coil pack kits, so the 34 just "fits" a little nicer by comparison.
Sounds good, thanks for the explanation. I'm not on stock height coils, so I doubt 34's would be an option but I'll measure to confirm. Reason I ask is the 36's have been discontinued since the beginning of 2023. NGK has no direct replacement. I just ordered another spare set.
Thanks!
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
