What are your intake temps? if you're hitting over 60, time for a new FMIC. You'll be surprised at the power gain to be had with decent IATs.
What is the best way to check intake temps Johnny?
I used a thin 1.5mm thick K thermocouple between a hose and the fmic with the sensing part around the middle of the flow. Plug it to an egt gauge and you have a reasonably accurate iat reading.
I made a measurement on my car last year and with 30℃ ambient temp the iat rose to 43℃ near the limiter in fourth.
either buy a compatible IAT sensor and weld it on the cold side of your IC (never install it into your plenum like the OEM 32/33 GTR as it heat soaks) and run it back to your ECU or just a basic gauge on eBay with an open sensor (probably wrong term used) ie fast sensor not the solid ones that react slow similar to your oil/water sensor
Just for the record the IC Tao uses is shown in P550 of this thread . I didn't go back far enough initially but chased a link to it from elsewhere .
I'll be ordering one Monday and looking into the 100 C cat as well .
Also my IAT sensor is in the back of my cast X over pipe and I'm wondering if it is heat soaking because of it .
A .
A .
Iat sensor is fine there. I have mine there and it only heat soaks if the engine is off. Doesn't take long to go back to normal once driving.
I'll have to take some logs next weekend. Mine is on the cold side right behind the radiator and it heat soaks incredibly bad.
If you turn the car off and come back a few minutes later and go to drive it feels like its around 60+deg and for me thats around -5 deg timing. It takes a long non stop drive for the power to come back slowly. Even though the sensor has an insulation seal, it doesn't stop the radiator heat from soaking into the sensor itself.
I will be moving it to the chassis rails section of the ic.
Hey Tao I was wondering if maybe I could get a quote to rebuild my stock r33 gtst s1 turbo was on your site earlier just trying to get ballpark figure im also located in okinawa if thats gonna be an issue shipping and all?
Hi, we can supply a donor turbo for $150 so you will not need to send one in. The cost to high flow is $850 for G2 that is made for stock ecu and fuel system, while the upsized G3 cost $900, that supports around 260rwkws on P98 fuel, but will require a custom tune and bigger injectors to work. postage to Okinawa is about $150. Oil line is included in price quoted.
  • Like 1
  • 3 weeks later...
3 minutes ago, -S- said:
Guys,
Let's say the vtc plug wasn't connected during a tune... does the car require a retune if u connect the vtc plug?
Yes.
The tune should be checked either way.  VCT changes both the engine VE and the build of cylinder pressure, which means timing and fuelling requirements will change with versus without VCT engaged.
  • 4 weeks later...
17 minutes ago, inmaniac said:
Hey guys.
Just wondering who here has experience with the standard "G2" high flow and what your real world results were?
Cheers!
I'll be honest with you, if you go through the efforts of removing the stock turbo to replace, you might as well go for something that's going to be of a decent size.
Thanks for the reply dude.
I was thinking the same thing, and therefore I wanted to go G3, but my understanding is the wastegate for this is set to 18psi. I'm hearing conflicting things that this might be too much boost for my 209xxx km engine (despite being well maintained, 200k service, etc)
Happy to hear opinions. Supporting mods: NISTune, Z32AFM,3in Turbo back + high flow cat, Walbro 255, 550cc injectors.
Goal was originally 240rwkw but am happy to temper expectations based on reliability.
Nah, that's rubbish. It's not boost that blows apart motors, it's timing and or torque.
I "had" a 300 000+ motor running with 1.8bar worth of boost for a good amount of time and thrashed regularly at the track too. It died about 3 years later lol
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
