What are your intake temps? if you're hitting over 60, time for a new FMIC. You'll be surprised at the power gain to be had with decent IATs.
What is the best way to check intake temps Johnny?
I used a thin 1.5mm thick K thermocouple between a hose and the fmic with the sensing part around the middle of the flow. Plug it to an egt gauge and you have a reasonably accurate iat reading.
I made a measurement on my car last year and with 30℃ ambient temp the iat rose to 43℃ near the limiter in fourth.
either buy a compatible IAT sensor and weld it on the cold side of your IC (never install it into your plenum like the OEM 32/33 GTR as it heat soaks) and run it back to your ECU or just a basic gauge on eBay with an open sensor (probably wrong term used) ie fast sensor not the solid ones that react slow similar to your oil/water sensor
Just for the record the IC Tao uses is shown in P550 of this thread . I didn't go back far enough initially but chased a link to it from elsewhere .
I'll be ordering one Monday and looking into the 100 C cat as well .
Also my IAT sensor is in the back of my cast X over pipe and I'm wondering if it is heat soaking because of it .
A .
A .
Iat sensor is fine there. I have mine there and it only heat soaks if the engine is off. Doesn't take long to go back to normal once driving.
I'll have to take some logs next weekend. Mine is on the cold side right behind the radiator and it heat soaks incredibly bad.
If you turn the car off and come back a few minutes later and go to drive it feels like its around 60+deg and for me thats around -5 deg timing. It takes a long non stop drive for the power to come back slowly. Even though the sensor has an insulation seal, it doesn't stop the radiator heat from soaking into the sensor itself.
I will be moving it to the chassis rails section of the ic.
Hey Tao I was wondering if maybe I could get a quote to rebuild my stock r33 gtst s1 turbo was on your site earlier just trying to get ballpark figure im also located in okinawa if thats gonna be an issue shipping and all?
Hi, we can supply a donor turbo for $150 so you will not need to send one in. The cost to high flow is $850 for G2 that is made for stock ecu and fuel system, while the upsized G3 cost $900, that supports around 260rwkws on P98 fuel, but will require a custom tune and bigger injectors to work. postage to Okinawa is about $150. Oil line is included in price quoted.
  • Like 1
  • 3 weeks later...
3 minutes ago, -S- said:
Guys,
Let's say the vtc plug wasn't connected during a tune... does the car require a retune if u connect the vtc plug?
Yes.
The tune should be checked either way.  VCT changes both the engine VE and the build of cylinder pressure, which means timing and fuelling requirements will change with versus without VCT engaged.
  • 4 weeks later...
17 minutes ago, inmaniac said:
Hey guys.
Just wondering who here has experience with the standard "G2" high flow and what your real world results were?
Cheers!
I'll be honest with you, if you go through the efforts of removing the stock turbo to replace, you might as well go for something that's going to be of a decent size.
Thanks for the reply dude.
I was thinking the same thing, and therefore I wanted to go G3, but my understanding is the wastegate for this is set to 18psi. I'm hearing conflicting things that this might be too much boost for my 209xxx km engine (despite being well maintained, 200k service, etc)
Happy to hear opinions. Supporting mods: NISTune, Z32AFM,3in Turbo back + high flow cat, Walbro 255, 550cc injectors.
Goal was originally 240rwkw but am happy to temper expectations based on reliability.
Nah, that's rubbish. It's not boost that blows apart motors, it's timing and or torque.
I "had" a 300 000+ motor running with 1.8bar worth of boost for a good amount of time and thrashed regularly at the track too. It died about 3 years later lol
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
