What size and price did you them for? I think we get a little touched up in SA as I payed $260 a corner for a 245/45-18.
Same; 245/45/18; $190 each, and that was fitted, with the old tyres disposed of too. http://www.ebay.com.au/itm/180788168695?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_1849wt_1037
I paid $260 each for the first set I bought for mine, but that was 2 odd years ago.
Same; 245/45/18; $190 each, and that was fitted, with the old tyres disposed of too. http://www.ebay.com....#ht_1849wt_1037
That's a great price Dale. You must have worked a deal 'cause that listing doesn't mention fitting & balancing, plus you obviously went in as opposed to having them shipped to you.
I got these the other day. By the time they were shipped & fitted it added ~$35 per tyre, but oh my are they nice to drive on.
I looked at the Invo's too Leon, from that seller in fact. And at that price why wouldn't you?
I read a bunch of reviews and they certainly get high praise; I'm interested to hear your thoughts on their wet weather grip, and also their longevity too.thumbsup.gif
I was shocked when they didn't charge me for fitting/balancing or disposal; I was expecting another $15-$20 per tyre. Lucky I guess...biggrin.gif
Although, with the number of cars they pushed through while I was there, they obviously just make profit on volume. Seriously, in 45 mins; they must've fitted tyres to at least 10 cars, and done at least 4 wheel alignments. That and other tyre places picking up uteloads, and mechanics bringing in punctures.
There was a lot of bustle, but everyone was just getting on with it. A bit like a pit crew. And it was all on show, so they can't really get away with being rough.
Fitted a couple of Aero catch type (didn't realise they weren't the genuine ones till they arrived but they seem to work ok) locking flush bonnett pins - not just for motorsport reasons but so that I could get rid of my bonnett catch and make room for my oil cooler and power steering cooler.
Glad you had a good experience from Tempe...I've read a few threads on here that makes me twice about bringing my car there if I was in Sydney.
I was going to buy a set from Tempe but in the end OTR Motorsports in Clayton fitted them on my car for $200 a corner...
Just bought the nismo suspension off troy. Hoping to have them fit for goldcoast cruise this sunday
Just a little info for you.....I have found that if I cut about 2/3's off the top coil on the rear springs it not only levels the car out but settles down the rear of the car quite a bit.
The shocks have also been sitting for quite a while so may need to be compresses a couple of times to wake them up.
oh and well done on the AWESOME parts buy! :P
Edited by Jetwreck
Thans for the info mate and yes they are awesome. But thats just personal opinion. When u say 2/3 of top spring u mean before it opens to full coiled diameter?
the top of the spring.......there is a "AWESOME"....sorry Nismo logo on the spring! :P ....the Nismo logo should be the right way up.
Put em in first and see how it settles....but I am pretty sure you will lower the rear a little not only to soften it off a little but to reduce the wheel barrow scenario!
So the Nismo awesome springs need to be hacked up with an angle grinder to sit right? So glad I went with BC's. lol.
agreed ^^^
on topic - I've done nothing to my Stagea today. I can't drive it. I'm starting to get withdrawal from not having it in my garage! blush.gif
Booked in for the SAUSA Track Day on April 16.
Plan before then is:
- Make and fit suction pipe (this Saturday)
- Fit catch can
- Fit shift kit and trans cooler
- Fit fuel pump and injectors
- Fit wideband
- Tune Fcon
- Buy and fit power steering cooler
- Fit toe arms, camber bolts and SuperPro bushes, then wheel align
- Buy and fit new wheels and tyres
- Fit braided brake lines, replace fluid
Not sure I'll get everything done. Priorities are probably power steering cooler, wheel alignment, and finishing the brakes off.
LOL. If we look at your past history I'd say that statement is right on the money.:P
But keep us posted as I'm interested to see how your car goes on the track.
Edited by Commsman
some things still need to be enhanced!
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
