Im running Aarons old Turbosmart compact, with the stiff spring it still runs fine. I only changed as the stock one wasnt coping too well at over 30psi, even with the grub screw mod.
How is my stock one going Jase? Prince Skyline had the same farting problem so I gave him my stock one to try. Seems to be a common problem.
Got the cruise sorted, finally! Works great, thanks to Leon for sorting and all the help. Probably just need to turn the gain down at some point I think.
Also got the other fog light switched over to spotlight with HID. Looks great, and very happy to have matching lights again. Looks much better matching. Was thinking about adding squid rings to fill the gap between old and the smaller new lights, but can't find anything with the right ID. Don't think it matters for now.
Next project is fuel pump while I wait for the SuperPro bushes and camber bolts to turn up.
Can't wait to get a wheel alignment - pulled one of the rears off on the weekend and the inside edge is all feathered. New wheels and tyres go on as soon as it's been aligned! :banana:
Took some shots of the spotlights tonight, just as it started to get dark. :thumbsup:
I actually like them now, I think I prefer the slightly smaller lights.
You can see I still need to finish cleaning the silicon...
Lights on!
For those interested, the lights are Narva 100mm spotlights with a HID conversion kit I got on ebay. Pretty easy to mount in the end, you just have to remove the Cibie glass so you can reuse the mounting hardware. Narva lights were ~$70 for the pair, and the H3 HID kit was ~$35.
My only issue now, as per the other thread, is Nissan don't allow the fog lights and high beams to be on at the same time. So according to Iain I need to wire up a diode and relay to fix this. Can go on the list!
They look great when on Ryan - nice job. I'm tempted to convert mine. Do they throw out a decent beam?
I can't think of the last time I actually used mine as fog lights, but Murphys' Law states that as soon as I change them I will need to travel a long distance in the worst fog in living memory.
Not yet - still have to work it out. Iain thinks he knows, I'll see if I can work it out.
I did this for a set of foggies on a Liberty years ago. I had a 2 position switch that allowed me to either a) lock them on, regardless of headlight position, or b) have them turn on & off with high beam.
That made them a practical addition. What would annoy you, & oncoming traffic lol, is if you had to dip head lights & also turn of the driving lights as a separate action. I'd be happy to play around & help out with a circuit.
Seem to Leon, but I haven't had a chance to try it out in the dark yet. Will do so this week. A single was great though, much better than the foggies.
That was my logic too... too hard to find a new fog light, and I never used the foggies. Spotlights are much more practical.
If you can figure out a circuit, that'd be great. It's not that high on my list at the moment, but the switch idea appeals.
Use the high beam 12v+ at the light and run that to a relay. So that when you turn the head liht on the relay will turn on. Then on the contact run a new circuit from battery (fused) and to a on/off switch and then through the relay contact and then to spotties.
So the spotties will only work when on high beam and then you can turn them on or off via the switch. Even if you leave the switch on the spotties will still turn off when on low beam via the relay.
That's all good, except if you want to run the spotties without high beam (or any head lights). That's why I previously used a 2 position switch, with the other position simply operating another relay to turn them on constantly. Of course that was before everyone started running with fog/driving lights on during the day & the police started cracking down on such use. To keep it nice & legal, maybe best to stick with only on when on high beam....
On the weekend I checked over my adjustable arms (camber/traction) and dropped the suspension 2cm allround. May drop it further, but will do a week of driving and go from there.
post-58831-0-06660300-1329199764_thumb.jpg post-58831-0-38074800-1329199802_thumb.jpg
Also removed the rear wing and debadged the boot.
Fitted Blitz LM panel air filter... :blush: The old K&N looked horrible.. After serving good time in the R33 and now the M35, time for a clean and maybe retirement...
Thanks Jason :thumbsup:
RDA slotted discs and HPX pads go in on Friday as the old girl gets serviced... Looking forward to non-shuddery brakes...
Out of curiosity, what did that set you back?
ask boostin imports in the trade section, they've usually got pretty good prices. mine were 799 for all 4 (different car though)
Replaced the bottom headlight bulbs, but now going to look into what the top ones are. Tomorrow aiming to get the new LED parkers in, and hopefully run the wiring for the new fuel pump, if not get it all finished.
Got in it today though to find the air con blowing hot air for the first time, and three of the four windows won't go down. I think the thermo fan is buggered.
Also picked up a small trans cooler today to use as the power steering cooler. Think it will be ok, hopefully won't be too small.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
