Atm, me and 4bidn1 have removed hypergear G3 and sent if of to get new design rear turbine wheel, replaced 044/surge tank setup
with intank 460 walbro, shifted Z32 into cooler pipe in a 3 inch alloy tube, and changing water injection system to a air/water atomiser setup
with no pump.
and looks wise have fitted a vented carbon fibre bonnet, just need ganadors now to finish it off..
cheers
darren
Finally took a pick with the Akebono's on. Nice to fill out those rims :)
Getting there slowly, bit by bit. Need the other front bar & spoiler fixed & modified next I think, then back to under the bonnet stuff
  • Like 1
Looks great Cam; what are your underbonnet plans with this one?
Needs the other front bar back on first, this one is the aero-less spare that I modified in my non-pro plasti-welding fashion :unsure:
Planning to chuck on some headers and my decat pipes... but I plan to install hydrogen injection prior to that for a number of reasons, one of which is a reduction in emissions/smell due to a lack of cats.
Still have quite a list of planned changes after those (quite a list actually) so will see how we go...
Edited by iamhe77
with no pump.
cheers
darren
Your new turbo ;) :
Did 80k service + fitted my de-cat/ed dump pipe. Pretty surprised at how much better it goes, can only imagine how good it would be with a proper aftermarket one.
Now have to install wideband O2 to the front pipe, then it's ready for tuning
  • Like 1
Oi I did ask you and you said they were ok!!! :whistling:
Why can't Cihan print out dyno sheets...LOL
Also, everyone thought I had an air leak somewhere...cos there's a pretty loud hissing noise when it hit boost.
Edited by ironpaw
Cihan can print dyno sheets, when the printer has paper. :P
It's not hard to check for boost leaks, unless you want it done remotely... Drop down mate.
Finally got my gas struts regassed today; no more getting belted in the back of the head when I throw backpackers in the boot.
Guess I'll have to get a bat or something to knock them out now.
  • Like 1
Traded mine in yesterday....
Sad to see it go after 5 years good service, but a 09MY 370GT sedan is helping...
Been a great few days in Melbourne for a 245kW rwd car... :-) missing the AWD already..
Nice!
Can you get the sedan in a manuel, or are they all auto?
