On 12/14/2018 at 5:54 AM, NicPM35 said:
Does that mean the rear weight of the car is now on the 2 small bolts holding the original shock in place? Assuming the spring is no longer in it's perch
Correct. I've been running MCA Street Performance Series coilovers in my M35 since March and honestly cannot fault them. I've also had a full car load of passengers as well as a loaded boot and they held up perfectly fine. MCA are a company I wouldn't doubt in the least.
  • Like 1
  • 1 month later...
So after about 2 years at 297ATW KW I need more. dropped my 260RS of at Maatouks Racing last Thursday, motor should be out by Wednesday this week to get a full build done. Not sure what will be done yet until the block & crank are inspected but either way 650KW ATW should be happening in about 6-8 weeks. Going back down this week to pick up the car without the motor so I can tidy up a few things while it easy to get in & under the front end. The boys were impressed with how clean & straight the old Stagea is so I'm sure they'll look after it, as soon as I get more info & they start the work I'll post update & picks. Wish me luck...
  • Like 2
lol that should get you to the shops OK!
  • 2 months later...
9 weeks any news yet?
Still waiting they had a few things come up like responding to JUN2 beating their 1/4 mile time   I don’t want to rush them as it’s not easy to get work done on a Stagea by a GTR specialist  plus the wife has a M135i BMW (278KW) & I  have a Harley & a BMW sports tourer as well.
Yea it should get me to the speed limit very fast. ?. Still waiting they had a few things come up like responding to JUN2 beating their 1/4 mile time   I don’t want to rush them as it’s not easy to get work done on a Stagea by a GTR specialist  plus the wife has a M135i BMW (278KW) & I  have a Harley & a BMW sports tourer as well
  • Like 1
  • 3 weeks later...
Finally got around to installing my 4G wireless router. Bought this for ease of use with the Raspberry Pi rather than hot-spotting off my phone each time. It's mounted in the passenger-side cubby and power tapped off the stock Japanese tuner. It automatically turns off with accessories. The car switch for the Raspberry Pi has stopped working though... Contacted the vendor but might have to buy another one.
Also setup the OB Link. Works perfectly. Does everything I want except trans temp.
  • Like 1
  • 4 weeks later...
OK so its started Fully forged RB30 1000HP bottom is being machined & built & my RB26 head is also being machined & upgraded, soon for all the new parts to be ordered. The crank decided the direction I headed - see uploaded image & find the fault :) Anthony Maatouk has come up with just what I wanted a bullet proof forged motor...
Edited by TMLP
changed .HEIC to .jpg files
  • Like 1
Bought mine another battery, it was fine on Friday but dead today. It hardly moves since we got the Leaf, and the battery was churning out a massive 0.03V this morning when I checked it. Not ideal considering I'm off on a 600km business trip on Friday.
I think one of the bonnet hinges has collapsed as the bonnet is catching on the left-side quarter panel when I open it, takes quite an effort to get past the point of resistance but eventually it goes "BANG!" and everything moves freely again. :P The tip of the quarter panel is rusting now after all the rubbing but meh, it's just the beater these days. One day maybe I'll show it some love. Maybe.
OB link looks nice. What are you using the Pi + 4G for?
Update: SOMEONE (not giving anything away but you can bet she's going to cook me some eggs*) left the dome light on, hence the drained battery.
*NZ in-joke.
Not much really. Mainly streaming music. Quite often it'll be on the Monstercat radio stream via Twitch or stuff from my YouTube subscriptions which are automatically downloaded using youtube-dl. It also has RetroPie installed with a heap of ROMs and an 8BitDo SNES Bluetooth controller. 4G is just for convenience.
  • 2 months later...
Ok bottom end done full NITTO 3L grout filled & brace adapter for the sump & front diff. Waiting on the head ?
Exciting! What turbo do you have lined up?
That is badass, my dude. Very keen to see where this goes haha.
  • Thanks 1
Maatouks are picking everything based on the power & reliability I asked for so apparently a Precision but I don’t know what one yet. As soon as I get the specs & parts list I’ll post it.
Got rid of the HKS pods and went back to a standard airbox, but since I run a MAP sensor , no AFM. Haltech ECU instead of standard and FCON PRO, Had new Longer BC inserts put in the front suspension to raise the car off the ground. Just waiting for a MOMO Factory wheel to turn up. All fluids changed, new battery. New radio,new tyres. New cam belt and water pump and new secondhand heater box, and fix sundry leaks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
