There is a setting for metric in there. Use that and everything changes.
Hi Chris
I read somewhere in a Canadian forum that the setting in the US cluster preferences changes all to kph except the actual odometer. This continues to show miles (and I assume count up in miles). Is this true? e.g. I get we can flash eprom to make the odometer show current car kms but if it continues to count up in miles it will quickly become inaccurate.
Also a lesser but annoying item with US cluster is that kph is the inside ring and the outside larger lettering shows mph. I have not found anybody selling a new facia but this guy could be asked.
http://www.blackcatcustom.ca/infiniti_g35.htm
Edited by mybrains
Thanks guys, yes CDN seems the go. In my hunt I see both Nav and non Nav versions of the speedos. Whats the difference? I would have thought the cluster didnt have anything to display nav wise (but maybe it has something to do with providing the nav system with driving info?
I have a Nav car, but am currently seeing a non Nav CDN speedo. I wonder if it will work (or can be modded to work - maybe by transferring something from my existing JDM cluster?)
I'm quite interested in changing over my dash cluster screen to display in English too, but is there any reason we can't just change the actual screen components within our jap clusters???
Or are people just changing the whole cluster because it's near on impossible to find just the actual screen itself without buying a whole cluster?
BurtoN86,
inside is pretty integrated (screen to main PCB and externally to ECU) and I doubt the lcd swap alone would work but hell, give it a go and report back.
Also the facia on JDM models only goes to 180kph whereas Canadian goes to 260kph so a facia swap wont work by itself either. Its just much easier to swap the unit whole and be done.
I scored a Canadian FX35 08 cluster a will attempt to use it in a 2010 EX35... physically looks the same but no idea if it will swap. If not, anybody with a FX can contact me for a Eng 260kph speedo :)
Edited by mybrains
BurtoN86,
Dont think the FX series were ever sold in japan under the Nissan badge thus none out there with 180km/h cluster either imo...
  • 4 weeks later...
  • 1 month later...
Ah, you're missing out on the most fun thing: learning to give voice commands in Japanese. Stinking hot day and saying "Air con ju-hachi do" gets a few laughs from the passengers. :P
I tried this today and had a good giggle. Got any more commands I can try? :D
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
