That one works fine cheers mate! That BOV would be getting very hot without heat shielding I imagine, did he go to a full race metal cover? I hadn't heard any mention of the noise these things made either until Greg mentioned it. Hopefully the 6758 is just as noisy but it has the type a front which isn't anti-surged and only 2.5" inlet.
4 hours ago, rb30det_ said:
Has anyone here run a EFR 9174 or 9180 1.05Ar on a RB30 or Stroker??  Looking at running a Borgy on a 26/3.4. But cannot decide .. Looking to see what would work best in a drift car
for a 3L or 3.4L the single EFR will choke.  Twin EFR is my recommendation.
2 hours ago, R_34 said:
What is the boost target ?  If lower than 25psi on a 3.4L go 9180 1.05 a/r.  If higher than that go 9174 1.45 as the compressor will spin close to the max rpm the 80mm turbine can take.
both of those options will likely choke due to backpressure on a 3.4L engine
7 hours ago, Lithium said:
Weird, ok this then
some more photos of similar
  • Like 2
Has anyone here run a EFR 9174 or 9180 1.05Ar on a RB30 or Stroker??  Looking at running a Borgy on a 26/3.4. But cannot decide .. Looking to see what would work best in a drift car :)
Long thread but 8374 on 3.2 results towards the end
both of those options will likely choke due to backpressure on a 3.4L engine.
Ever taken any EGP readings on combo's like this, Geoff?
Page 26 on this thread has my result on a 26/3.2 EFR8374
Tune #1 done, I was a bit concerned about this happening but it is what it is - the BW EFR internal wastegate is a big pile of fail and blows open as exhaust pressure builds.  The turbo itself seems to perform awesome, VE is holding nicely up to 7000rpm so far and no hints of excess back pressure, intake temps never reached 30C... I'm going to try and get video of the gate opening as rpm increase despite having 80% duty on the boost control solenoid.
256kw at 14psi, hitting 18psi by 3500rpm - will be revisited at some point with a Turbosmart dual port actuator.  Car drives basically like a Euro, it spools better on the road than my Mazdaspeed 3 with the stock K04 :O
  • Like 2
In case folks hadn't been following, the above is a T3 0.83 internally gated EFR7064 on an RB25 - btw.
A helpful mate has offered use of his high pressure BW actuator to test out on this car to make sure that fixes it before buying things, thanks @Sub Boy32!    Hoping that it allows us to hold around 18-19psi, or whatever it seems appropriate to run :)
  • Like 3
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
