Hi Geoff
Just to clarify would a EFR9174 "super core" , would fit my 8374EFR? Or does the housing needs to be modified?
Its on a street/weekend 2.7L 33 GTR with all supporting mods, I've got the feeling with 8374 EFR (400-450 awkw) I could go bigger later ,so might as well do it now .
Thanks
Bruce
15 hours ago, Shyboy said:
Hi Geoff
Yes, 9174 supercore will be plug and play for 8374 EFR turbo.  you dont need to remove the turbine housing, just loosen the cam bolts and swap supercores.  let me know if you need one we have a few incoming
On 5/3/2017 at 6:20 PM, Nismo 3.2ish said:
I was wondering if the 8474 is still being tested or dropped completely ?
still being tested.  you will probably get some more hints at sema.  The other EFRs will not change or get discontinued, they all remain relevant and have their place
  • Like 1
I've finally got my twin 6758 kit in the mail at the tuner's this week, so the build begins. Pretty excited to see what it will do both on the dyno and on the street. Will post full results in a month or two once it's done.
  • Like 2
30 minutes ago, Robzilla32 said:
What application is it best suited to? Most people on this site seem to bag the twins and say big (usually EFR) single is the way to go.
I am still interested to see more as well, There has been a lot said about them and I can see the potential but there is so little real world info I am treating it as unchartered territory so stick to what I have more an idea about.
For what it's worth, the main issue I have with twins on GTRs is stock location packaging etc - any turbo is a single turbo for what it's worth.
I would love to see turbine speed sensors on twins going into a common plenum.  @Full-Race Geoff, have you guys done any turbine speed logging with the twins kits?
Edited by Lithium
They overlap though, so even if there's 2x 6258's they're just walking into 8374/9180 territory.
Could only imagine twins if going for truly stupid power on a 3.4L or something like that?
I dont know many people on this site who bag twin EFRs, but single EFR is most common and for good reason: excellent performance and simple to retrofit existing greddy or HKS installations.  Twin IWG works better than single IWG and twin 6258s have a noticeably better throttle-link-to-boost-response than the big 9180.  Its not for everyone, but we have some customers in russia, europe and japan who are now only purchasing our twin RB kits. twin EFR means no dumptube headaches and no backpressure issues choking on 0.92
we have logged on the 6258 2.8L car here but it runs well and reliably, doesnt require much oversight.  the twins are almost never operating near max speed limits or emap choke points like the big singles so its not been nearly as critical as with the 9180 or 9174/8374.
in terms of mass airflow rate, twin 6258s are a little bigger than a single 8374.  but smaller than 9174 or 9180.
Edited by Full-Race Geoff
Sorry my post wasn't worded very well. I meant to refer to twins in general being considered inferior to a modern big single. I was wondering if there was something different about the EFR solution that changed that thinking?
Cheers
Do you have any data on it?  I often wonder if the front and rear ones work similarly hard or if there are situations one may end up taking more load than the other.  I'd guess that more likely with stock location twins, but still curious
  • Like 1
Thats something im actually curious about.
Speed sensors on both turbos to see just how they both share the work load together.
Curious if its the rear turbo that works harder like the factory stuff does?
Obviously the removal of that horrible "twin turbo pipe" would help eliminate most of that.
Cheers
The 'twins' comparison you see around here is alawys done in the context of rb26 stock location/piping GT28 twins, vs singles. That somewhat skews things.
Doing a full custom twins vs full custom single with no constraints (read AC/PS pump in the way) and using EFRs for both you'd probably find the comparison quite different to an 8374 vs -5's for example
  • Like 6
2 hours ago, bri73y said:
My twin 6258s made over 700hp at all four last tune. All in (28psi) at around 4700rpm. Not too shabby.
Sounds mad :)
Please post the graph and any other info, love to see it
Which GTR was this in? I am working on doing the twin setup on mine as well but am having issues with the power steering pump. Did you have an R32? Did you replace your p/s pump with something else?
Nice!  Is the R33 still cranking with the 7670?
Out of interest the single EFR9180 on my mate's RB28DET is all in at about the same boost at similar rpm.
Edited by Lithium
You need to use an R33 or R34 power steering pump, then everything will fit.
  • Like 1
Sure is, can't see that changing anytime soon, it's a great combo for anything you want to do. It's currently having a makeover with a wide body kit and respray in Audi Nardo Grey. It's nearly complete, looks good, but most importantly I will now be able to run my GTR wheels/tyres (wider) under her.
Yes, Brett (from Full Race) has told me several times there's no real advantage in going 9180 over my twins.I did try the larger rears (0.8) on the twins last year chasing more power but gained bugger all whilst losing easily 400-500rpm in response.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
