Well, after almost 3 months, tomorrow is the day, when the GTR comes home...for a bit. An extensive amount of work has been completed, marking another step in the cars evolution. Still a long way to go before it’s finished, but I’m happy that a lot of the ‘little things’ are now sorted.
The car went on the dyno to sort out a boost creep/spike issue, it had a blend of 98 and e85 and was at about 15% ethanol content. It made 420 awkw on the rollers @20psi (gate pressure) and that’s wearing Toyo R888 tyres.
looking forward to getting it back and taking it for a run.
  • Like 5
3 minutes ago, PranK said:
Fantastic! And she looks great too!
Hey, any chance of a video of the dash working? A few keen beans on insta have asked.
No problem, I’ll get one up on the weekend
  • Like 1
Yes, it’s really nice. Was good to drive the car again, forgot how bloody fast this thing is. Even on gate pressure running 98 the thing is an animal on the street. But you can feel the reduced power in the top end, but it’s really strong through the mid range.
I found out the motec uses the wheel speed and rpm. The gear ratios have been entered in so it can determine what gear it’s in. Actually works really well.
  • 7 months later...
Well this never ending build is finally moving forward. Car is going to the shop after GTR festival to have the motor removed, then it’s off to get the bay painted, then the new 2.7 stroker motor is going in. I’m also replacing the cooler to a Plazmaman 100mm comp spec and the entire hot side. Going a 6boost manifold with egt bungs for each cylinder and new turbo will be a Precession 6875.
And while I’m there Pro wire will be making me a new custom engine loom and cleaning up all the other wiring in the bay.
after this I’d like to think the bay is finished? If there is such a work in the GTR world 🤔
  • Like 1
6 hours ago, MoMnDadGTR said:
nice unit mate, hell of a read. that dash is wicked too
Cheers, it’s been a long road, with many ups and downs. Hopefully at some point I’ll get it to where I want it.
Ahh don’t get to caught up in the details mate. Don’t get me wrong you have done a job I couldn’t never do my engine is a hack compared to that lol. But it’s good to be content and enjoy what you have! Your car is wicked mate go bag the piss out of it. Cheers.
  • 3 weeks later...
Well, I’m going back to a 2.6 based motor, just in the process of getting everything together, things getting re-furbished, coated or replaced with new where I can. Car is at the painters now, decided to paint the bay the colour of the car. Also sold my hotside so it’s being replaced with a 6 boost manifold and 68/75 turbo. I’ll also be running egt’s and getting a new engine harness . But one thing at a time 🤔
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
