Atm, me and 4bidn1 have removed hypergear G3 and sent if of to get new design rear turbine wheel, replaced 044/surge tank setup
with intank 460 walbro, shifted Z32 into cooler pipe in a 3 inch alloy tube, and changing water injection system to a air/water atomiser setup
with no pump.
and looks wise have fitted a vented carbon fibre bonnet, just need ganadors now to finish it off..
cheers
darren
Finally took a pick with the Akebono's on. Nice to fill out those rims :)
Getting there slowly, bit by bit. Need the other front bar & spoiler fixed & modified next I think, then back to under the bonnet stuff
  • Like 1
Looks great Cam; what are your underbonnet plans with this one?
Needs the other front bar back on first, this one is the aero-less spare that I modified in my non-pro plasti-welding fashion :unsure:
Planning to chuck on some headers and my decat pipes... but I plan to install hydrogen injection prior to that for a number of reasons, one of which is a reduction in emissions/smell due to a lack of cats.
Still have quite a list of planned changes after those (quite a list actually) so will see how we go...
Edited by iamhe77
with no pump.
cheers
darren
Your new turbo ;) :
Did 80k service + fitted my de-cat/ed dump pipe. Pretty surprised at how much better it goes, can only imagine how good it would be with a proper aftermarket one.
Now have to install wideband O2 to the front pipe, then it's ready for tuning
  • Like 1
Oi I did ask you and you said they were ok!!! :whistling:
Why can't Cihan print out dyno sheets...LOL
Also, everyone thought I had an air leak somewhere...cos there's a pretty loud hissing noise when it hit boost.
Edited by ironpaw
Cihan can print dyno sheets, when the printer has paper. :P
It's not hard to check for boost leaks, unless you want it done remotely... Drop down mate.
Finally got my gas struts regassed today; no more getting belted in the back of the head when I throw backpackers in the boot.
Guess I'll have to get a bat or something to knock them out now.
  • Like 1
Traded mine in yesterday....
Sad to see it go after 5 years good service, but a 09MY 370GT sedan is helping...
Been a great few days in Melbourne for a 245kW rwd car... :-) missing the AWD already..
Nice!
Can you get the sedan in a manuel, or are they all auto?
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
