Not so much a what have I done but a what I will do when the wife and kids give me 5 minutes of peace!
Next on the list will be coilovers, looking at MCA, Blitz ZZ-R and BC BR RS.
Anyone running the Blitz or MCA or anything else they are happy with?
whats in the innovate box mate?
Whats the fitment like with the blitz kit? Hit a possum a few months back and have been having random boost leaks since and I've narrowed it down to the cooler itself being warped and not sealing properly, with my current HDi cooler.
Thinking to just replace the core but the blitz kits tempting whats left of my "JDM yo" honda feelings
Thrashed it at the Snowy 1000
Ran 22.49 @ 233.5 kph, better ET than I expected but was hoping for a quicker trap speed.
Was quite happy the wagon was able to drive home as many cars didn't survive the day.
  • Like 1
Ok so as promised....
I had more time to spare to go check out the M35 as we get closer to the end of this long job,
I managed to take a few happy snaps of a few bits.
Clutch pedal is sorted.
Manual box in place
Centre console test fitted
Tail Shaft not in yet...
But the best bit is.... IT STARTS!!! The 4wd light is on + the auto light flashes a few times on start up but it stars perfectly and idles fine.
Next the hand brake will be sorted + clutch line and then all i am waiting on is the tail shaft which i was hoping to be done before this week ends but looks like next week.
There are heaps more photo's that have been taken by the mechanic but they will sorted once all is done.
Edited by Beregron
  • Like 9
not much but bidding (nengun) "new" air conditioning center panel
I bought already 2din player
xenon reverse lights :rolleyes:
still should put the engine heater.. now outside temprature -15°
:mad:
still should put the engine heatertill should put the engine heater
hey maybe we should rename this thread to " What have you hidden from your missus lately "
so far I've done high flow, ( she knows that one but not the total cost ), brakes, rotors, pads, bov, boost t and sway bars.
sitting in my cupboard I have two Greddy BOV's, new set of plugs, intake coupling and clamps, new fuel pump and strainer, an AMPerformance intake with heat wrap, and lastly an E-Manage Ultimate in a box.
Add it all up and it's a holiday to Thailand.
if she knew I'd be a f**king grease pop. ;)
  • Like 2
It won't run cooler with the Nismo thermostat - it will just take longer to warm up. Stock is best.
Not true actually.
OEM opens at 86deg, so you'll never see it colder than that in normal running.
Nismo opens at 74deg, so my car routinely runs around 80 deg; except in very hot weather.
OEM does keep temps more stable, but only when using an OEM radiator.
Not true actually.
how about your car with heavy traffic on 40 degree day?
Edited by YangLIU
Your thermostat is not like the unit on the wall that controls your central heating - it just increases the flow through the radiator and once its open the Nismo is no different from the stocker so on a hot day both will be open but the amount of cooling done by the radiator will be exactly the same i.e. a thermostat that opens at a lower temperature will not cool your engine any better than one that opens later once that temperature has been reached.
  • Like 1
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
