Needs more RB25DET NEO Head
Anyone have one?
Needs to be unraped, at a minimum it will need all its cam caps, buckets (cam followers). Of course, I'll take a complete head as that's probably better.
I have a raped one you can have. 2000 of your finest Covid dollars please.
Seriously though. Been looking for one for the last 6 months. Nobody is selling because they need their 8 spares. Have lost so much hope that a small part of me is whispering sweet nothings about selling the whole project. Shit times.
  • Sad 1
yeah that sucks. I was lucky when I had a cam break due to an oil problem, was the second last journal and no piston damage. Did need a new head though.
do you know the root cause of the failure yet?
RB = oil issues lol
From what Alex at Birrong has gathered the restrictors in the block were not small enough, too much crank case pressure from 2bar of boost and as the NEO doesn't run a front head drain/vent there's even more crank case pressure stopping the oil from flowing back down the sump.
From here we will be welding fittings in the sump (above the oil line) to vent the crank case pressure, fitting a catch to sump drain (and only using it on track days, block off for street duties), retaining that additional crank case vent to catch can then fitting 1.1mm restrictors in (and yeah, fitting a head drain too)
  • Like 1
15 hours ago, Dose Pipe Sutututu said:
At this rate putting in a RB26 seems cheaper.
just put a destroked Barra in it & Samsonas
https://62f5fb6a-14c7-4556-8f38-df35dec2dcbe.filesusr.com/ugd/3dc2cf_720f980c4e8d4229b254bf0988dd2b7c.pdf
    • Nah, turn the boost up, break the gearbox, and enjoy leaving it parked for a few years while you save for a better box...
    • I see those two Stageas have the "punched 40mm hole" deregistered Japanese number plates 👍 Nice kouki group shot with the different colours too.
    • Ended up just being a loose exhaust bolt luckily.
    • Yeah I made that post way too early, sorry I must have assumed it was bad because it's a 20+ year old thrashed shitbox lol. It was just a loose exhaust bolt.
    • Like others have said, drop the power to give your drivetrain a % of reliability until you can up the drivetrain reliability  It isn't rocket science, build power to the weakest link with a % of safety Whilst upping the the reliability of the drive train is costly, there's no point in having the engine make big power if it keeps eating the drivetrain....ask me how I know, I had the tow truck on speed dial for a few years, and I spent huge amounts of money fixing issues and breakages that really would have been cheaper in the long run if I did it right the first time Me, I like a nice sized fudge factor, that keeps me off the tow truck
