10 hours ago, Kinkstaah said:
You let the Nissan out
Realistically, 300kw. Use it. Enjoy it. Potentially even use it again 😛
I know, and all I did for years was say NEO headstuds dis dat 400kW... hypocrite I am 😂
New goal, reliable 500kW.
  • Like 1
Given we see 1000hp+ turbo LS stuff doing over 400 passes and over 20 thousand road k's , I don't see why not.
At that power I'd call it reliable.
All about how it's built and how it's used.
15 hours ago, BakemonoRicer said:
lol 500KW & reliable......
Go spend 100k and then tell me if you achieve reliability. Pls m8.
No thanks.
Rather go buy another investment property.
All about how its presented on Insta. The breakages get left out when you're trying to sell reliability.
  • Like 3
Paint looks magic mate, good job!  Selenite is a Benz colour from memory? Goddam old car ownership can be frustrating!  Glad you’re giving it some love, hopefully she’s back on the road in no time!
When GT3 racecar manufacturers (Mclaren, Porsche, Acura, Nissan, many other mfg's) all have 500 HP engines lasting 60 hours of use time, or, 12,000km of use (I mean, its track kms though obviously) you know that if they could have made that more reliable... they would have - given they have a massive interest in doing so by having a more reliable motor than their competitors.
And they are not cheap cars, nor cheap engines...
But um... nah mate I have 1000kw for 8 years no breakdowns bruh #bulletproof
  • Like 1
  • Haha 1
Thank you 😁 and yes, it's from a MB lol.. don't hate.
58 minutes ago, robbo_rb180 said:
Since anything Japanese car related is stupid money have you thought of putting the BMW 335 motor and box it?
At least it won't blow oil pumps and smash boxes lolol..
Good news, I've found another block too. Hopefully back on the road soon.
  • Like 1
I found my old neo crank if it's any use to you send me a message, otherwise will put it up for sale. What a reasonable price for a crank in perfect condition came from a running 100,000km engine? Also have full set of pistons (who wants standard pistons though) and rods (same as RB26 so may be worth something,)
Crank is still a short nose crank, same as any other RB25 so not hugely sought after. If its in great condition is doesn't need a grind then maybe ~$200. If its got some gouges or enough where to warrant anything more than a links then the nitriding will be removed and I'd say its pretty worthless, 50 bucks maybe but more likely a bin job.
Pistons for the bin.
Rods, these days probably not so popular anymore, people probably more likely to go with a set of Chinese forgies if they are building a cheap motor. Maybe $150?
Yeh this is the thing - a track car actually uses 500hp. If you have a car that once made 500kw on the dyno, but all you do is drive it 20kms to work everyday at under 3000rpm - you don't have a reliable 500kw car, you have a reliable 120kw car haha. And even then, you will probably still find yourself pulling it down before it ever gets close to 50,000kms.
Nobody is jumping into their 160,000km-since-rebuild 500kw Skyline, driving it to the track and thrashing it for 3 hours, then driving it home. Nobody.
  • Like 4
15 hours ago, Murray_Calavera said:
Has the replacement block been crack tested?
Will be soon, usual checks. If this one is also cracked I will have a sads.
See how I go, hopefully my old crank isn't cactus, if it is I'll message you 😊
And don't worry, I'll send the next motor too. Test and learn, worked out I need more crank vents and even smaller restrictors with an even larger sump. Next motor will last, I'm confident it will.
  • Like 1
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
