2 minutes ago, Phat_Toni said:
Very interested to see how the G30 based turbos compare to the GT30 based turbos in terms of response. Im expecting response somewhere between GT30 and GT35 in comparable housing sizes...time will tell
A mate is going to be trying a Gen2 GTX3076R with 1.01a/r hotside and a G-series turbo for comparisons sake, not 100% sure which but it seems like it could end up being a G30-770 with .83a/r hotside (most similar flow rating to the 1.01 GT30) on a built SR20VE.   That should be a relatively interesting comparison.
Edited by Lithium
  • Like 5
I'd like to hear those results...
On 18/07/2019 at 12:11 PM, Lithium said:
I saw a post on Sinco NZ's Instagram page which made me think of you, how is your build going?  Did you end up going Sinco for the manifold or is there someone else doing similar?
Progress pic...Snapchat-1139584873.thumb.jpg.a226fa3f2b7d36ee8c75b5e3d340a30f.jpg
  • Like 4
G30 660 and 770 at jamboree last weekend. Asked about t3 or t4 housings possibly in the future but only doing vband housings for now. They are a direct bolt on replacement for g25 series too.
Edited by robbo_rb180
More info
  • Like 2
I was just looking at the dimensional drawings at the ATP site , it appears that Garrett have used three slightly different compressor housings .
The G25-550/660 and G30-660 use a 0.70 AR housing , the G30-770/900 and G35-900 a 0.72 housing , and the G35-1050 a 0.75 housing . From memory their diameter's are around 170 190 and 205mm .
A
  • Like 1
So, are they going to be doing the T4? Or did they not answer the question? I sure hope so.
They said no at the moment. Maybe in the future. Would have liked to try one in t3. 92 on a Rb25
I have a G30-900 0.83 on order with an 8-10wk wait,currently 2wks in, the anticipationis killing me, but just to top it off I had purchased a GTX3584RS the day before they were released ??? so I returned it for the G30-900 instead. I don't mind dropping up to 100HP for farrr better spool. I anticipate 700awhp out of my 2.4L built MPS. The big cams and the oversized pistons should get it spooling early, tbh my biggest worry is that it might choke it up top
Edited by Yaji
  • Like 1
  • 1 month later...
hey fellas, just had a read thru. thought id chip in.
ive been running the .92 g25-660 for about a year now. semi closed forged ej25. amazing turbo, spool, mid range everything. almost as responsive as the tiny factory td04.
in my humble opinion, this is too small for an rb. you'll get mad response, but no top end.
runs about 340awkw at 26 psi. under very strict controls, pulled timing, torque limit etc.
clutch and semi closed engine holding us back. still makes 100kw at 95kph, and 200 kw at 110kph.
have since exploded that clutch, now have a new twin plate on there and a more efficient cooler. if i get it back on the dyno any time soon, ill drop back round to post the sheet.
we also, have a sleeved ej28 stroker in the build hopefully to have a g30-770 or g30-900 attached to it. with the current wait times, and gcg having the monopoly (and also charging full price upfront to non traders) it could be a while. once MTQ has stock, we will be all over it.
  • Like 3
  • Thanks 1
that is great feedback!  I absolutely love the G25 with 0.72.  The 0.92 flows a ton (very impressive actually) but did have some response loss.  I would love to see any boost logs you can share.
and if you wanted to try G30-770 we have them in stock at full race
here are the dyno results. incredible spool, amazing torque and a very long power band (for a subaru)
28psi by 3800 rpm. thats plenty of response! unfortunately the stock heads are killing me with its tiny cams and weak springs. would like to see this with 272s springs, and a 4 inch exhaust.
i raced it at the weekend in the local sprints. such an amazing car to drive. cannot talk highly enough about this turbo!
edit the previous run of 340kw was done at a higher ramp rate. it was dropped to 10 for this.
on the shoot out mode that some "tuners" like to print out, should made 370kw at all four. gotta love dynos :)
  • Like 3
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
