Not so much a what have I done but a what I will do when the wife and kids give me 5 minutes of peace!
Next on the list will be coilovers, looking at MCA, Blitz ZZ-R and BC BR RS.
Anyone running the Blitz or MCA or anything else they are happy with?
whats in the innovate box mate?
Whats the fitment like with the blitz kit? Hit a possum a few months back and have been having random boost leaks since and I've narrowed it down to the cooler itself being warped and not sealing properly, with my current HDi cooler.
Thinking to just replace the core but the blitz kits tempting whats left of my "JDM yo" honda feelings
Thrashed it at the Snowy 1000
Ran 22.49 @ 233.5 kph, better ET than I expected but was hoping for a quicker trap speed.
Was quite happy the wagon was able to drive home as many cars didn't survive the day.
  • Like 1
Ok so as promised....
I had more time to spare to go check out the M35 as we get closer to the end of this long job,
I managed to take a few happy snaps of a few bits.
Clutch pedal is sorted.
Manual box in place
Centre console test fitted
Tail Shaft not in yet...
But the best bit is.... IT STARTS!!! The 4wd light is on + the auto light flashes a few times on start up but it stars perfectly and idles fine.
Next the hand brake will be sorted + clutch line and then all i am waiting on is the tail shaft which i was hoping to be done before this week ends but looks like next week.
There are heaps more photo's that have been taken by the mechanic but they will sorted once all is done.
Edited by Beregron
  • Like 9
not much but bidding (nengun) "new" air conditioning center panel
I bought already 2din player
xenon reverse lights :rolleyes:
still should put the engine heater.. now outside temprature -15°
:mad:
still should put the engine heatertill should put the engine heater
hey maybe we should rename this thread to " What have you hidden from your missus lately "
so far I've done high flow, ( she knows that one but not the total cost ), brakes, rotors, pads, bov, boost t and sway bars.
sitting in my cupboard I have two Greddy BOV's, new set of plugs, intake coupling and clamps, new fuel pump and strainer, an AMPerformance intake with heat wrap, and lastly an E-Manage Ultimate in a box.
Add it all up and it's a holiday to Thailand.
if she knew I'd be a f**king grease pop. ;)
  • Like 2
It won't run cooler with the Nismo thermostat - it will just take longer to warm up. Stock is best.
Not true actually.
OEM opens at 86deg, so you'll never see it colder than that in normal running.
Nismo opens at 74deg, so my car routinely runs around 80 deg; except in very hot weather.
OEM does keep temps more stable, but only when using an OEM radiator.
Not true actually.
how about your car with heavy traffic on 40 degree day?
Edited by YangLIU
Your thermostat is not like the unit on the wall that controls your central heating - it just increases the flow through the radiator and once its open the Nismo is no different from the stocker so on a hot day both will be open but the amount of cooling done by the radiator will be exactly the same i.e. a thermostat that opens at a lower temperature will not cool your engine any better than one that opens later once that temperature has been reached.
  • Like 1
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
