21 minutes ago, robbo_rb180 said:
Sucks to hear about bank drama. Freeing up some dollars for a BMW or more Reno's?
Freeing up some money to upgrade the house and hopefully find a place with either a double garage or a shed 30mins from Sydney CBD.
Wish me luck lol, maybe BMW afterwards ?
@Unzipped Composites should touch base with Ben at Thirdstrike Fabrications. He's ex-Hypertune and he uses the same cores too.
  • Like 1
7 hours ago, Dose Pipe Sutututu said:
To keep @iruvyouskyrine happy ?
I really need to find a new R33 shell and move everything across. So much rust and shit on this one.
I've been looking for a rust free R33 for a while now, I'm starting to think rust is factory fitted :(
  • Haha 3
Please do this. How would you bonding to aluminium go with the pressure?
5000psi lap shear strength and even higher burst strength... it should be ok with boost pressure ?
Heat is the bigger issue. Id like to do some data logging and record how hot the IAT's get in various situations. If it gets over 150° sustained for any period of time then it could be an issue.
  • Like 1
3 hours ago, Jasoncauser said:
have you got a pic of how you did the sump breather on the sump end?
Just so I can get an idea on what I gotta do :)
I actually just used the unused VCT head drain/breather as the R34 NEO motor doesn't use it. Fitted up a 3/4NPT to 10AN fitting, and ran that to the catch can.
As circled in blue (not my photo). With R33 RBs that is attached to the head to that blank flange next to exhaust of Cylinder 1.
However, I feel that it's still pushing out some oil. I handed the keys to my friend to go thrash it around "Mexico" after we fitted everything and there's still a decent amount of oil droplets forming in the catch.
Find out soon enough, decided to go track day on the 14th of September LOL.
  • Like 1
Thanks mate.
I havent checked but im guessing the RB20det dont have that, so will have to do it a different way
Track Day - sweet. Wakefield again?
If they open it up to spectators I may come down for a watch as mine wont be ready for a while with bathroom reno starting soon.
  • Like 1
My vote, lowball this > https://www.carsales.com.au/cars/details/1988-BMW-3-Series-320i-E30-Manual/SSE-AD-6762530/
No rust project car.
You will end up with your BMW, but it will be reliable, well, Nissan reliable anyways.
That would be well cool, and different.
  • Like 1
@Jasoncauser hitting up Wakefield, try get sub 10s with the shitty AR-1 tyres. Then will get better tyres afterwards :)
@mlr let's see, if the next place is big & has a shed will make doing silly swaps much easier
  • Like 2
Wrong side of the crank?
@mlr that's an expensive donor chassis.  Nothing special about an E30 except light weight, and compact dimensions.  Body lacks rigidity. Rear semi trailing arm suspension very similar in concept and execution to a Datsun 180B.  And the 80s spec M20 donk is even less exciting than a RB20E, plus more expensive to overhaul.
If Dose gets any urge to look at that, I will send him a pair of knitting needles.  The pain of those jabbed in the eyes will take his attention away from the BMW. :)
  • Haha 3
Yes correct, however just seeing if it makes any difference to relieving crank case pressure.
You would at least imagine it's doing something at the very least (as Nissan had it on the R33 motor). If this doesn't work out, motor out and welding on a couple of 12AN fittings to the sump and also will run a head to sump vent too.
I'm sure it does something. But perhaps being on the pressure side of the crank means it doesn't make as much difference as it should. Oil will be getting pushed up that line by the crank windage for sure. But it does probably also provide a path for the crank gasses without going up the drains. So it is maybe helping with the actual oil control problem, but you're still getting oil in the catch can simply because it is under pressure.
For the R33 that wouldnt have mattered, that oil was just going back to the head rather than being evacuated completely.  Interesting that they didn't use it on the 34 though....
Solid lifters vs. hydraulic is probably the reason.
  • Like 1
If anyone shops at SipnSave or Bottlemart or Harry Brown, use the code SAVE20 at checkout (today only) and save $20 for orders over $100 (excludes cancer sticks & delivery).
shop.bottlemart.com.au
shop.harrybrown.com.au
shop.sipnsave.com.au
Yeah, I might have some affiliation but whatever, cheap grog LOL
NHB Automotive ? are doing 12% off all Elig Brake Pads for the month of August, no minimum sets required.
www.nhbautomotive.com.au
  • Like 2
Looks like I'm driving in supports for supertaxi in Townsville so will be able to give a good review of the Elig pads. Trying to get a few people onto them up here.
  • Like 2
@robbo_rb180 they're a pretty decent street/track pad as they give you near track pad performance but a street pad feel, ie not much heat required.
New day, new part, and wasted more money ?
Now to find time to delete the haram clutch dampener.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
