9174 alloy supercore finally arrived today. I'm surprised how light it is. The housing I was looking at adapting won't fit so I'm looking for a t4 1.05 TS housing if anyone has one for sale.
Anybody have any feedback on the alloy core vs iron core?
Re: that twin gate setup
Not worried about melting the lid/diaphragm of the gate that is almost in direct contact with the dump pipe, on the track?
I got lots of 'worried looks' about where my gate sat and it was nowhere even close to the dump as that one is?
There is actually an air gap between the 2 of them, the image is a little deceiving... Everything will be heat coated so i guess its a matter of try and see how it goes!
The back gate is sitting just under the old ABS unit area that is being removed this week, its pretty tight one all the pipes start going together!
Putting it into my 34 with a 7670 and only the one gate it was pretty tight and lines and heat shielding went bonkers to hopefully not melt it all. I recall thinking "I'm glad I don't have a 2nd gate here" I actually thought for my application I should have gone IWG and would recommend IWG to anyone else due to it..
Then again, twin gate seems to be working OK for all the GTR guys, and in your application you don't need pesky things like AC or other daily concerns taking up space. If your wastegate lasts then I can be happy mine will too. Wrap all the things! :1310_thumbsup_tone1:
Well ill make sure we keep an eye on it and ill provide feedback! In that side of the engine bay there is now nothing but what you see in that pic above... Everything has either been relocated or deleted coz race car :)
The bonnet pulls a lot of heat from the engine bay on track too... It'll be a lot less in the way of heat issues now than it was with the old turbo setup!
pft, that's nothing compared to what the 6boob twin gate manifolds put them :P
Anyway, due to a series of events car is now at different workshop, with the turbosmart WG with a 7psi spring and no boost controller, so creeping to 9psi, made 370hp at rears. Apparently on the ramp up on the dyno at least, it already has a couple of psi by 2000rpm. Tuner seemed pretty surprised with it in general.
Downside.... lot of valve train noise. Valve clearences are all over the shop (12thou-22thou IIRC). Brand new head... very dissapointed. So waiting on that, and my next 2 weeks away at work, to actually get the car back.
How many cases of failing wastegates have you heard of due to the placement of the twin wastegates on 6 boost manifolds?
we have the 1.05 a/r TS housings in stock.  also 1.45 in stock if you have a built motor.
the alloy core requires mandatory watercooling AND mandatory 360-degree clamp plate kit.  Without the upgraded clamp plates, the alloy core will get damaged at the turbine housing connection.  we have these in stock if you need them, it appears very few of the other distributors are aware of those
When we began experimenting with twinscroll setups (2002-2003) cramming dual wastegates in places where there was only room for one gate was typical for early test units.  this did work for a brief amount of time (enough to get test data).  However the diaphragm location at or near the turbine housing/downpipe will result in diaphragm failure before too long.  even if you have a water circuit and high end fluorocarbon diaphragm
Edited by Full-Race Geoff
no idea, but i wasn't saying if it would or wouldn't be a problem..just that its next to the merge.
the alloy core requires mandatory watercooling AND mandatory 360-degree clamp plate kit.  Without the upgraded clamp plates, the alloy core will get damaged at the turbine housing connection.  we have these in stock if you need them, it appears very few of the other distributors are aware of those.
are you able to send me a price on 1.05 housing and clamps to suit alloy core thanks
41 minutes ago, Griffin said:
What are you guys using for a readout of the speed sensor?
https://www.full-race.com/store/electronics/road-rage-gages-rbt-kit-speed-boost-temp-1/
I saw your car down at the tuners when I picked up my mates 33 today! Looks awesome man, keen to see what it does on a proper tune :D
7 hours ago, R377 said:
34GeeTeeTee
You had a good run with your HTA turbo, what made you decide to go for a BW over say the next HTA up like a 3582 ?
It actually wasnt the turbo that i wanted to upgrade, it was everything supporting it such as manifold, gate and dump... So i figured if i was going to that expense i might as well look at alternatives. I spoke to a lot of people and this "EFR" topic came up a fair bit... So i looked into it and it seemed to fit the bill... Ill find out mid next week if i made the right choice :ninja:
Turbo, manifold and gates had final fitment today. Dump pipe has been test fit and we are already to complete the assembly tomorrow.
Once we fab the rear section of the exhaust and the intake pipe etc we will be ready to fire it up. Should be running tomorrow arvo and on the dyno soon after.
We took the time to delete the ABS and re-route some wiring and coolant lines etc away from the heat, doing as much as we can to get some reliability.
Here is the ceramic coating on the gates -
  • Like 2
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
