  • 3 weeks later...
Build / events/ story
this will be a condensed version because a million things have happening in the last 3 weeks
After making the car pretty and complete above went for a private test day to get back in the seat - limited laps due to time running out but sorted alot of gremlins and tweeks out and could tell the car felt more balanced and was happy to end the day with some good runs
End of that week I went  down to our other track at Collie for a round of our state sprint series - the track is more technical and good corner flows hadnt driven the long track basically - by the end of the day was starting to get a handle on the track and car ended up getting class win and 2nd overall to a radical
48025928_CollieNov22.thumb.jpg.f37fcdf54e59680bae170180b8ade641.jpg119603472_Collie2Nov22.thumb.jpg.78e85db57199cfbfb8a877608179bbb0.jpg
We'd had a good day and thought we'd do one more session and go home not doing the last session but on the last lap - bang ...   the death rattle what turned out to be a rod bolt failure and put a hole in both sides of the block
With WA Time attack only 13 days way that we were gearing up for this was not great at all let alone blowing the engine fullstop
WA Time attack is our premier event for what I want to race in and being in little old Perth its hard to get anywhere else to race with ease so we try to work towards this as our big event for the year
All the round abouts and stories in between but basically we decided to have a crack at getting a billet engine in the hole for the event as this was our next move and a long term solution anyway - it was just being accelerated time wise
Pulling out and cleaning dry sump lines/ system and 12ltrs + of oil off a car is not a fun job especially in a time crunch but we got to it
We decided due to time constraints etc we would just run the old turbo setup as that would be bolt on and no fab needed so we stayed with that
finally got the thing in the hole and base idling with 2 days to go
Tune the next day everything went well and the result surprised us
This is a Nitto RB2.7 running 11:1 compression with a full house Neo head and the little Gen II GTX 3582 pumped out the powas  making 845 rwhp on the hubber at 33psi
Next day was full prep mode late into the night but we got it done
The first 2 sessions we battled engine cutting out with fuel cut issues, then we broke a suspension part the guys got to it
Eventually we got a lap in won the event and put down a time attack lap record that Ive been chasing for a while
1232484709_WATADec222.thumb.jpg.e9f8d495ad3f372cbd655812d2632b5b.jpg450038840_WATADec22.thumb.jpg.ecc7ef93ef15dcfb6c48498562095627.jpg
Will just keep chipping away at the things we have planned and get more seat time as have to learn to drive the car as the way its tuned now is very different with throttle and way the power comes on etc which will be a good challenge as a driver to be able to push this to 10 tenths again will be fun
One of the bigger things to come out of this for me is the car doesnt overheat at all the introduction of the new PWR crossflow rad and the Plasmaman cooler has just been awesome with lower IAT and resulting overall lower temps for everything therefore better engine performance has been great
Edited by bcozican
  • Like 10
  • Thanks 1
Congrats on the lap record and win thats a massive achievement itself plus everything behind the scenes.
One thing you could do with the dbw you could try is make the 0-50% pedal area = 0-35% TB as an example to give you a bit more pedal down low. Some times this can help make power a bit more linear but can cause issues as airspeed can be faster and make more power.
Look at that torque curve, would love to see an overlay with the old motor.
thanks !
yeah they did change the throttle / pedal situation to prob somewhat what youve just outlined, didnt have a chance to get into details yet so much going on
its extremely drivable compared to what Ive had previously even at significantly more HP now
Im used to having to feather onto the throttle coming out of corners due to the ramp up etc but dont have to now so will have to learn to get onto throttle earlier on apex not after
this is with a borrowed Motec M130 also new M150 with pro torque mapping etc package incoming
Below is like for like new vs old motor biggest things I think being higher compression, smaller cams and adding back VCT that I didnt have before as last tuner took it out
Edited by bcozican
  • Like 3
Sounds like a hell of a fortnight, well done getting through it and taking the win!
It's great to have a team of people behind you to get it to the track and fix it when you are there as well, that makes all the difference in getting results.
  • Like 1
11 hours ago, Roy said:
Oh my!!!!!
thats says and covers I think 😅
thanks was hetic for sure
100% agree I think most of us would agree racing is racing but without mates there and helping and all kinds of things we'd be stuffed half the time and it would be as good either
Im still blown away at how much effort gets put in so I can go race
while this seems like a big flashy car etc and might well be, this is not a cheque book workshop build (as such) we did 70% of this in my garage at home and then when at the workshop I played courier, cleaner and tool passer etc all late into the night there with them
like you guys would ... you put in the effort yourself and look after those that help you and it goes along way !
56 minutes ago, sav man said:
Brad knows how to build good engines
he does .... and alot of other things also. very knowledgeable and helpful (for the right people ha) and has been a huge help in the recent development of the car over and above just all the shiney bits
37 minutes ago, Dose Pipe Sutututu said:
VCT sure makes a massive difference, I still don't understand why people keep on deleting it when it's not really that hard to manage in the first place!
Wild powerband!
yeah I did question it years ago when it was done but went with what I was given now much better
amazing the difference in VCT and small cams (260 poncams) vs no VCT and big cams (278 kelfords)
drivability especially out of corners with the mapping etc vs throttle blaa blaaa is so much better
  • Like 2
Far out, that was some shit luck with the dual positive block ventilation system but wow what an epic effort to get it all re done and back together within the timeframe.
Coming away with the win must have been mighty satisfying. Congratulations man, well deserved, this thing has come a long long way. Definitely a serious machine and contender. Keep kicking those goals 👍
  • Thanks 1
So whats the thinking on the plenum? Very different type of comparison but i lost torque and response on my 310rwkw RB20. So i was going to RB26 plenum my 2.8L Neo build. Easier to run a plazmaman or even std. My Kinder Surprise RB25DE with no VCT beats RB26 on same dyno, fuel and turbos and can only put that down to the long runner inlet.
Does the torque mapping mean you have what you can use so plenum isnt as critical? Thats assuming its not bettercat response power and torque which may have been your experience
Ive had that plenum on forever since there wasnt many options and from my experience Ive seen better torque and similar power with nearly every incarnation of diff setups Ive had along the way vs similar .. and then you calcuate the $ spend vs any marginal benefit of the newer ones also... disclaimer on sub 600hp setups
Tbh now... its just a $ elsewhere first thing to improve the car other places and get it to the track
I do want to change it though just because
But when one of the better rb builders and tuners around atm says its completely fine and wont stop you making everything we'll need... it will stay at the back of the list for now
Torque mapping just used to get the engine up to speed as quick as possible / inputting desired torque level with being within the tyre slip window and not blowing the tyres off for the turbo taking over  for the power in higher rpm
This plenum will still let us do all that
This will live between 5k to 8.5k rpm and new turbo combo 5 to 9k so response as such not needed but its also there If i stuff it 😆
Edited by bcozican
  • Thanks 1
  • 1 month later...
Updating to a Motec M150 GPRP Pro package with all the gear to try and manage this thing moving forward and help a rank amateur like myself to extract the most I can out of this car eventually
this is going to pretty much require a full car rewire but given the first incarnation of the car was 8 years ago with just a basic package you know what its like when you start adding this and splicing that etc everything just gets outdated and messy.
This will go in very soon and be coupled with a new hot side of Artec exh mani and G35 1050 thats been sitting on the shelf for a while
  • Like 2
16 minutes ago, Dose Pipe Sutututu said:
I am noticing a trend here, MoTec + RB25 NEO head + GTS-t = fast track car lol.
crazy how that works hey ... can you guess who helps me develop my car ?
9 minutes ago, ActionDan said:
Serious car is serious.
What's the longer term goal here?
to be honest just challenge myself .....which in my current chosen discipline is just go as fast as possible probably until Ive reached my limit, something happens that I  dont want to do it anymore or change direction
Will apply for WTAC '23 and aim to drive some different tracks over time to get out of little old Perth
  • Like 3
Fair enough, I think about this a lot as I chip away at my build(s). What do you think is your limit? $$? Until you crash/come close? Until you win at a certain level etc?
Andrew Hawkins? Does it have a Western Sydney Mode too? LOLOLOL..
There are similarities between your car and Brad's car I must say.
  • Haha 2
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
