Custom shroud and 16’ Spal fan. And the battery is being relocated to the boot with a under bonnet surge tank being fitted. All the aftermarket wiring and relays are being  removed and it will all be controlled via a PDM.
I also bought a PRP coil pack bracket and stalks so I will be able to fit the valley cover back on, it’s been coated and fitted with a new R34 ornament plate.
  • Like 3
3 hours ago, Ben C34 said:
Under boner surge tank seems questionable, what's the thinking behind that?
For me, it’s to fill the space where the battery sits once it’s relocated to the boot. Benefits are better and more consistent  Fuel pressure, as the lines from the pumps to the rail are now significantly shorter. The rear of the car reverts back to standard with the only mod being the rubber lines upgraded to something e85 compatible. So no more aftermarket lines from the rear of the car to the front.
I never had this issue but also for set ups that suffer from fuel smell in the cabin, this eliminates that.
The only downside you might be able to argue is would the tank suffer from heat soak from engine bay heat? I can’t see this being an issue with where it’s mounted, on the cold side of the motor and furthest away from the motor. And it doesn’t just sit in place, it’s mounted in place so can’t move.
What are your thoughts on it Ben?
the heat soak is my main concern. I know drag cars do it, but they are hardly on so not a good reference!
As for the fuel pressure benefit, I dont think that is really an issue is it? Any half decent ecu can compensate for fuel pressure with a sensor (that you would surely run) if there is some discrepancy.
I imagine you have a flex sensor? they measure fuel temp also so depending where it is mounted you will tell if there is a heat soak impact of having the surge tank in the engine bay.
I get it makes for good use of space, but it does seem a bit bad in a crash.....
  • Like 1
  • 1 month later...
Well, it’s getting there, car is almost done, dash configuration is being completed, (it looks good) and the last bits and pieces are being fitted. With a bit of luck might have it home some time next week.
  • Like 3
So you're retaining the factory top hat with 5/16 in/out fittings, factory hard lines and 5/16 feed/return from surge tank to main tank ? What intank pump are you running ?
Yes, I believe this is the case, I know 100% they used the factory top hat and hard lines. I’ll have to look at the invoice to confirm but I believe they used a 255lph pump in main tank and two 460’s in the surge tank.
21 minutes ago, DaymoR32 said:
That looks amazing!
Thanks Daymo, I’m very happy with the result, not sure if you noticed but there are shift lights in the tacho, oil pressure gauge also gives oil temp, water temp gauge give water pressure, fuel level gauge gives fuel pressure, and where the trip metre should be gives boost.
  • Like 1
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
